取消
显示结果
搜索替代
您的意思是:
260 次查看
注册日期: ‎06-15-2019
zynq7020-linux系统下DMA驱动收发通道中断申请失败
各位前辈好:小弟的问题是这样:
vivado创建的dma收发测试,BD图如下:
通过petalinux创建工程,导入硬件信息。生成的设备树经过修改接收和发送通道后如下:
        dma@40400000 {
            #dma-cells = <0x1>;
            clock-names = "s_axi_lite_aclk", "m_axi_sg_aclk", "m_axi_mm2s_aclk", "m_axi_s2mm_aclk";
            clocks = <0x1 0xf 0x1 0xf 0x1 0xf 0x1 0xf>;
            compatible = "xlnx,axi-dma-7.1", "xlnx,axi-dma-1.00.a";
            interrupt-names = "mm2s_introut", "s2mm_introut";
            interrupt-parent = <0x4>;
            interrupts = <0x0 0x1d 0x4 0x0 0x1e 0x4>;
            reg = <0x40400000 0x10000>;
            xlnx,addrwidth = <0x20>;
            xlnx,include-sg;
            xlnx,sg-length-width = <0xe>;
            dma-channel@40400000 {
                compatible = "xlnx,axi-dma-mm2s-channel";
                dma-channels = <0x1>;
                interrupts = <0x0 0x1d 0x4>;
                xlnx,datawidth = <0x20>;
                xlnx,device-id = <0x0>;
            dma-channel@40400030 {
                compatible = "xlnx,axi-dma-s2mm-channel";
                interrupts = <0x0 0x1e 0x4>;
                xlnx,device-id = <0x1>;
驱动代码如下:
/*  axidmatest.c - The simplest kernel module.
* Copyright (C) 2013 - 2016 Xilinx, Inc
*   This program is free software; you can redistribute it and/or modify
*   it under the terms of the GNU General Public License as published by
*   the Free Software Foundation; either version 2 of the License, or
*   (at your option) any later version.
*   This program is distributed in the hope that it will be useful,
*   but WITHOUT ANY WARRANTY; without even the implied warranty of
*   MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
*   GNU General Public License for more details.
*   You should have received a copy of the GNU General Public License along
*   with this program. If not, see <http://www.gnu.org/licenses/>.
#include <linux/kernel.h>
#include <linux/init.h>
#include <linux/module.h>
#include <linux/slab.h>
#include <linux/io.h>
#include <linux/interrupt.h>
#include <linux/of_address.h>
#include <linux/of_device.h>
#include <linux/of_platform.h>
/* Standard module information, edit as appropriate */
MODULE_LICENSE("GPL");
MODULE_AUTHOR
    ("Xilinx Inc.");
MODULE_DESCRIPTION
    ("axidmatest - loadable module template generated by petalinux-create -t modules");
#define DRIVER_NAME "axidmatest"
#define DRIVER_NAME1 "axidmatest1mm2s"
#define DRIVER_NAME2 "axidmatest2s2mm"
/* Simple example of how to receive command line parameters to your module.
   Delete if you don't need them */
unsigned myint = 0xdeadbeef;
char *mystr = "default";
module_param(myint, int, S_IRUGO);
module_param(mystr, charp, S_IRUGO);
struct axidmatest_local {
int irq;
unsigned long mem_start;
unsigned long mem_end;
void __iomem *base_addr;
static irqreturn_t axidmatest_irq_mm2s(int irq, void *lp)
printk("axidmatest_irq_mm2s interrupt\n");
return IRQ_HANDLED;
static irqreturn_t axidmatest_irq_s2mm(int irq, void *lp)
printk("axidmatest_irq_s2mm interrupt\n");
return IRQ_HANDLED;
//DMA 基地址
#define DMA_BASE_ADDR 0X40400000
//DMA MM2S控制寄存器
volatile unsigned int  * mm2s_cr;
#define MM2S_DMACR 0X00000000
//DMA MM2S状态控制寄存器
volatile unsigned int * mm2s_sr;
#define MM2S_DMASR 0X00000004
//DMA MM2S源地址低32位
volatile unsigned int * mm2s_sa;
#define MM2S_SA 0X00000018
//DMA MM2S传输长度(字节)
volatile unsigned int * mm2s_len;
#define MM2S_LENGTH 0X00000028
//DMA S2MM控制寄存器
volatile unsigned int  * s2mm_cr;
#define S2MM_DMACR 0X00000030
//DMA S2MM状态控制寄存器
volatile unsigned int  * s2mm_sr;
#define S2MM_DMASR 0X00000034
//DMA S2MM目标地址低32位
volatile unsigned int  * s2mm_da;
#define S2MM_DA 0X00000048
//DMA S2MM传输长度(字节)
volatile unsigned int  * s2mm_len;
#define S2MM_LENGTH 0X00000058
#define DMA_LENGTH 16384
dma_addr_t axidma_handle;
volatile unsigned int * axidma_addr;
/*申请一大块空间
//axidma_handle :  返回地址是物理地址,让dma设备使用
//axidma_addr   : 该地址供系统调用使用,比如*/
//axidma_addr = dma_alloc_coherent(NULL,DMA_LENGTH,&axidma_handle,GFP_KERNEL);
static int axidmatest_probe(struct platform_device *pdev)
struct resource *r_irq1; /* Interrupt resources */
struct resource *r_irq2; /* Interrupt resources */
struct resource *r_mem1; /* IO mem resources */
struct resource *r_mem2; /* IO mem resources */
struct device *dev = &pdev->dev;
struct axidmatest_local lp1;
struct axidmatest_local lp2;
int rc = 0;
printk(KERN_EMERG "axidmatest_probe Device Tree Probing\n"); // v
dev_info(dev, "Device Tree Probing\n");// v
/* Get iospace for the device */
r_mem1 = platform_get_resource(pdev, IORESOURCE_MEM, 0);
if (!r_mem1) {
dev_err(dev, "invalid address1\n");
return -ENODEV;
printk(KERN_EMERG "axidmatest_probe 1 \n");
r_mem2 = platform_get_resource(pdev, IORESOURCE_MEM, 0);
if (!r_mem2) {
dev_err(dev, "invalid address2\n");
return -ENODEV;
printk(KERN_EMERG "r_mem1 = %p  \n",r_mem1); // v
printk(KERN_EMERG "r_mem2 = %p \n",r_mem2); // v
/* Get IRQ for the device */
////////////////////////////////s2mm////////////////////////////////////////
r_irq1 = platform_get_resource(pdev, IORESOURCE_IRQ, 0);
if (!r_irq1)
dev_info(dev, "no IRQ1 found\n");
return 0;
printk(KERN_EMERG "axidmatest_probe 8.1 \n");
lp1.irq = r_irq1->start;
printk(KERN_EMERG "lp1.irq = %d  \n",lp1.irq); // v
printk(KERN_EMERG "lp1.mem_start = %d  \n",lp1.mem_start);
printk(KERN_EMERG "lp1.mem_end = %d  \n",lp1.mem_end);
printk(KERN_EMERG "lp1.base_addr = %p  \n",lp1.base_addr);
rc = request_irq(lp1.irq, &axidmatest_irq_mm2s, 4, DRIVER_NAME1, &lp1);
if (rc)
dev_err(dev, "testmodule1: Could not allocate interrupt %d.\n",
lp1.irq);
goto error3;
printk(KERN_EMERG "axidmatest_probe 8.2 \n");
////////////////////////////////mm2s////////////////////////////////////////
r_irq2 = platform_get_resource(pdev, IORESOURCE_IRQ, 1);
if (!r_irq2) {
dev_info(dev, "no IRQ2 found\n");
return 0;
printk(KERN_EMERG "axidmatest_probe 8.3 \n");
lp2.irq = r_irq1->start;
printk(KERN_EMERG "lp2.irq = %d  \n",lp2.irq);
printk(KERN_EMERG "lp2.mem_start = %d  \n",lp2.mem_start);
printk(KERN_EMERG "lp2.mem_end = %d  \n",lp2.mem_end);
printk(KERN_EMERG "lp2.base_addr = %p  \n",lp2.base_addr);
//rc = request_irq(lp2.irq, &axidmatest_irq_s2mm, 4, DRIVER_NAME2, &lp2);
rc = request_irq(0x1e, &axidmatest_irq_s2mm, 4, DRIVER_NAME2, &lp2);
if (rc) {
dev_err(dev, "testmodule2: Could not allocate interrupt %d.\n",
lp2.irq);
goto error3;
printk(KERN_EMERG "axidmatest_probe 8.4 \n");
return 0;
error3:
//free_irq(lp1->irq1, lp1);
//free_irq(lp1->irq2, lp1);
error2:
//release_mem_region(lp1->mem_start, lp1->mem_end - lp1->mem_start + 1);
//release_mem_region(lp1->mem_start, lp1->mem_end - lp2->mem_start + 1);
error1:
//kfree(lp1);
//kfree(lp2);
//dev_set_drvdata(dev, NULL);
return rc;
static int axidmatest_remove(struct platform_device *pdev)
struct axidmatest_local *lp = dev_get_drvdata(dev);
free_irq(lp->irq, lp);
iounmap(lp->base_addr);
release_mem_region(lp->mem_start, lp->mem_end - lp->mem_start + 1);
//kfree(lp1);
return 0;
struct of_device_id
char name[32];
char type[32];
char compatible[128];
const void *data;
#define CONFIG_OF
#ifdef CONFIG_OF
static struct of_device_id axidmatest_of_match[] = {
{ .compatible = "xlnx,axi-dma-1.00.a", },
{ .compatible = "xlnx,axi-dma-7.1", },
{ .compatible = "xlnx,axi-dma-mm2s-channel", },
{ .compatible = "xlnx,axi-dma-s2mm-channel", },
{ /* end of list */ },
#endif
MODULE_DEVICE_TABLE(of, axidmatest_of_match);
static struct platform_driver axidmatest_driver = {
.driver = {
.name = DRIVER_NAME,
.owner = THIS_MODULE,
.of_match_table = axidmatest_of_match,
.probe = axidmatest_probe,
.remove = axidmatest_remove,
static int __init axidmatest_init(void)
printk("<1>Hello module world.\n");
printk("<1>Module parameters were (0x%08x) and \"%s\"\n", myint,
       mystr);
return platform_driver_register(&axidmatest_driver);
static void __exit axidmatest_exit(void)
platform_driver_unregister(&axidmatest_driver);
printk(KERN_ALERT "Goodbye module world.\n");
module_init(axidmatest_init);
module_exit(axidmatest_exit);
问题的现象:
请问下,是否我的设备树设置的问题,还是驱动编写的问题呢?有什么思路或者建议呢? 非常感谢!!!
0 项奖励
4 条回复4
204 次查看
注册日期: ‎04-15-2011
回复: zynq7020-linux系统下DMA驱动收发通道中断申请失败
你用的是什么版本的Petalinux?
你跑Petalinux自带的axidamtest会有同样的问题吗?
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842337/DMA+Drivers+-+Soft+IPs
我看到你这里面有两个driver, 有点奇怪。
0 项奖励
201 次查看
注册日期: ‎06-15-2019
petalinux2018.3 内核xlnx2015.1
0 项奖励
194 次查看
注册日期: ‎04-15-2011
peking428@163.com
如果你用2018.3 Petalinux去编译2015.1内核,那最直接看到的问题,是生成的dts版本与内核版本不匹配。
你能用2018.3内核试试吗?
另外,你的Vivado版本是多少?我们强烈建议Vivado,Petalinux,kernel版本一致。
0 项奖励
180 次查看
注册日期: ‎06-15-2019
感谢你的回复! 我只能用2015.1的内核版本,我们在这个版本上有移植特殊的软件,所以只能用这个版本了
0 项奖励
