修改时间 12-07-2020 10:30 AM
2020.1
petalinux-bulid
petalinux-package --boot --fsbl zynqmp_fsbl.elf --fpga --u-boot --kernel --force
烧写flash,重启,启动,仅能启动uboot,内核无法启动,什么原因??相同的方法我在2018.2上是正常跑起的,升级到2020.1后就不行。
U-Boot 2020.01 (Dec 05 2020 - 07:59:00 +0000)
Board: Xilinx ZynqMP
DRAM: 4 GiB
PMUFW: v1.1
EL Level: EL2
Chip ID: zu21dr
NAND: 0 MiB
MMC:
In: serial@ff000000
Out: serial@ff000000
Err: serial@ff000000
Bootmode: QSPI_MODE
Reset reason: EXTERNAL
Net:
ZYNQ GEM: ff0e0000, mdio bus ff0e0000, phyaddr 12, interface rgmii-id
Warning: ethernet@ff0e0000 (eth0) using random MAC address - aa:a5:c0:f6:71:4b
eth0: ethernet@ff0e0000
Warning: SPI speed fallback to 100 kHz
SF: Detected mt25qu02g with page size 512 Bytes, erase size 128 KiB, total 512 MiB
device 0 offset 0x3e80000, size 0x80000
SF: 524288 bytes @ 0x3e80000 Read: OK
## Executing script at 20000000
Wrong image format for "source" command
SCRIPT FAILED: continuing...
No MMC device available
no devices available
starting USB...
No working controllers found
USB is stopped. Please issue 'usb start' first.
starting USB...
scanning bus for devices...
修改时间 12-07-2020 10:52 AM
Hi @JZ
为了排除问题,建议先停在u-boot下,然后用u-boot指令手动把image/rootfs/dt load到ddr中,然后用iminfo命令查看下image信息,最后再bootm启动,看看在哪个步骤有问题。
如果帖子有帮助,别忘“接受为解决方案”或“奖励”。谢谢!
Don't forget to "Accept as solution" or "Kudo" if it helps. Thanks!
修改时间 12-07-2020 01:52 PM
使用以下命令可以启动:
tftpb 0x200000 Image
tftpb 0x7000000 system.dtb
booti 0x200000 - 0x7000000
ZynqMP> booti 0x200000 - 0x7000000
## Flattened Device Tree blob at 07000000
Booting using the fdt blob at 0x7000000
Loading Device Tree to 000000000fff3000, end 000000000ffff22c ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 5.4.0-xilinx-v2020.1 (oe-user@oe-host) (gcc version 9.2.0 (GCC)) #1 SMP Wed Dec 2 03:04:21 UTC 2020
[ 0.000000] Machine model: xlnx,zynqmp
[ 0.000000] earlycon: cdns0 at MMIO 0x00000000ff000000 (options '115200n8')
[ 0.000000] printk: bootconsole [cdns0] enabled
[ 0.000000] efi: Getting EFI parameters from FDT:
iminfo命令提示格式不对:
ZynqMP> tftpb 0x200000 Image
Using ethernet@ff0e0000 device
TFTP from server 192.168.1.154; our IP address is 192.168.1.11
Filename 'Image'.
Load address: 0x200000
Loading: #################################################################
3.5 MiB/s
done
Bytes transferred = 37716480 (23f8200 hex)
ZynqMP> iminfo
## Checking Image at 00200000 ...
Unknown image format!
