修改时间 09-28-2020 11:18 AM
7 series的MIPI D-PHY solution见XAPP894. https://www.xilinx.com/support/documentation/application_notes/xapp894-d-phy-solutions.pdf.
One is Compatible Solution, which is to use resistor network.
The other is Compliant Solution, this solution provides a high-performance MIPI D-PHY interface at the FPGA level using active components.
See XAPP894 for more info.
Please Kudo or Accept as a solution, If this Post helped you.
