取消
显示结果
显示  仅  | 搜索替代
您的意思是:
tomithy
612 次查看
注册日期: ‎02-23-2020
petalinux2020.1 编译后无法启动进入登录系统
跳至解决方案
ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
i2c /dev entries driver
cdns-wdt f8005000.watchdog: Xilinx Watchdog Timer with timeout 10s
EDAC MC: ECC not enabled
Xilinx Zynq CpuIdle Driver started
mmc0: SDHCI controller on e0100000.mmc [e0100000.mmc] using ADMA
mmc1: SDHCI controller on e0101000.mmc [e0101000.mmc] using ADMA
ledtrig-cpu: registered to indicate activity on CPUs
clocksource: ttc_clocksource: mask: 0xffff max_cycles: 0xffff, max_idle_ns: 447945978 ns
timer #0 at (ptrval), irq=42
usbhid: USB HID core driver
fpga_manager fpga0: Xilinx Zynq FPGA Manager registered
NET: Registered protocol family 10
Segment Routing with IPv6
sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
can: controller area network core (rev 20170425 abi 9)
NET: Registered protocol family 29
can: raw protocol (rev 20170425)
can: broadcast manager protocol (rev 20170425 t)
can: netlink gateway (rev 20190810) max_hops=1
e0001000.serial: ttyPS0 at MMIO 0xe0001000 (irq = 26, base_baud = 6249999) is a xuartps
of-fpga-region fpga-full: FPGA Region probed
input: gpio-keys as /devices/soc0/gpio-keys/input/input0
hctosys: unable to open rtc device (rtc0)
of_cfs_init
of_cfs_init: OK
ALSA device list:
No soundcards found.
Warning: unable to open an initial console.
Freeing unused kernel memory: 1024K
Run /init as init process
udevd[78]: starting version 3.2.8
random: udevd: uninitialized urandom read (16 bytes read)
udevd[79]: starting eudev-3.2.8
urandom_read: 2 callbacks suppressed
random: dd: uninitialized urandom read (512 bytes read)
运行至此,无法运行下去?求助!!!
0 项奖励
1 解答
已接受的解答
sdyang
594 次查看
注册日期: ‎12-01-2017
0 项奖励
1 回复
sdyang
595 次查看
注册日期: ‎12-01-2017
0 项奖励
