取消
显示结果
搜索替代
您的意思是:
Newbie sauron3145
3,023 次查看
注册日期: ‎07-18-2017
使用petalinux 增加QT库,导致image.ub变大,引导失败。
大家好,
  我用petalinux2016.4 在zcu102上 使用petalinux-config -c rootfs 选择了 packagegroup-petalinux-qt 然后我的image.ub编程了179M,在引导的时候就错误了,全部的引导信息如下:
Xilinx Zynq MP First Stage Boot Loader
Release 2016.3 Mar 8 2017 - 11:38:43
Platform: Silicon (3.0), Running on A53-0 (64-bit) Processor, Device Name: XCZU9EG
SD1 with level shifter Boot Mode
Bitstream download to start now
XPFW: Calling ROM PWRUP Handler..Done
XPFW: Calling ROM Isolation Handler..Done
PL Configuration done successfully
Initializing TCM ECC
PMUFW: PmInit:
NODE_APLL #3:
acpu #1 { NODE_APU }
gdma #1 { NODE_GDMA }
dp_dma #1 { NODE_DP }
dbg_tstmp #0 { }
NODE_VPLL #1:
dp_audio #1 { NODE_DP }
NODE_DPLL #2:
ddr #1 { NODE_DDR }
pcie #1 { NODE_PCIE }
NODE_RPLL #5:
dp_video #1 { NODE_DP }
dp_stc #1 { NODE_DP }
sdio1 #1 { NODE_SD_1 }
pcap #0 { }
pl2 #1 { NODE_PL }
pl3 #1 { NODE_PL }
timestamp #0 { }
NODE_IOPLL #29:
dbg_trace #0 { }
dbg_fpd #0 { }
gpu #1 { NODE_GPU }
sata #1 { NODE_SATA }
gtg_ref0 #0 { }
usb3_dual #0 { }
gem0 #1 { NODE_ETH_0 }
gem1 #1 { NODE_ETH_1 }
gem2 #1 { NODE_ETH_2 }
gem3 #1 { NODE_ETH_3 }
usb0_bus #1 { NODE_USB_0 }
usb1_bus #1 { NODE_USB_1 }
qspi #1 { NODE_QSPI }
sdio0 #1 { NODE_SD_0 }
uart0 #1 { NODE_UART_0 }
uart1 #1 { NODE_UART_1 }
spi0 #1 { NODE_SPI_0 }
spi1 #1 { NODE_SPI_1 }
can0 #1 { NODE_CAN_0 }
can1 #1 { NODE_CAN_1 }
cpur5 #1 { NODE_RPU }
iou_switch #0 { }
csu_pll #0 { }
lpd_switch #0 { }
lpd_ls_bus #0 { }
dbg_lpd #0 { }
nand #1 { NODE_NAND }
adma #1 { NODE_ADMA }
pl0 #1 { NODE_PL }
pl1 #1 { NODE_PL }
gem_tsu #4 { NODE_ETH_3, NODE_ETH_2, NODE_ETH_1, NODE_ETH_0 }
dll #2 { NODE_SD_1, NODE_SD_0 }
ams #0 { }
i2c0 #1 { NODE_I2C_0 }
i2c1 #1 { NODE_I2C_1 }
 ATF running on XCZU9EG/silicon v3/RTL5.1 at 0xfffea000, with PMU firmware
NOTICE: BL31: Secure code at 0x0
NOTICE: BL31: Non secure code at 0x8000000
NOTICE: BL31: v1.2(release):f2b7927
NOTICE: BL31: Built : 11:39:03, Mar 8 2017
U-Boot 2016.07 (Mar 08 2017 - 11:50:54 -0800)
I2C: ready
DRAM: 4 GiB
EL Level: EL2
Chip ID: xczu9eg
MMC: sdhci@ff170000: 0
SF: Detected N25Q512A with page size 512 Bytes, erase size 128 KiB, total 128 MiB
In: serial
Out: serial
Err: serial
Bootmode: LVL_SHFT_SD_MODE1
Net: ZYNQ GEM: ff0e0000, phyaddr 12, interface rgmii-id
eth0: ethernet@ff0e0000
Device: sdhci@ff170000
Manufacturer ID: 3
OEM: 5344
Tran Speed: 50000000
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 14.8 GiB
Bus Width: 4-bit
Erase Group Size: 512 Bytes
reading image.ub
186856520 bytes read in 12271 ms (14.5 MiB/s)
Using 'conf@1' configuration
Trying 'kernel@0' kernel subimage
Description: Linux Kernel
Type: Kernel Image
Compression: uncompressed
Data Start: 0x100000d8
Data Size: 14404608 Bytes = 13.7 MiB
Architecture: AArch64
OS: Linux
Load Address: 0x00080000
Entry Point: 0x00080000
Hash algo: sha1
Hash value: 67753c85d7b99303c2c673e6195fdd8f334c09b3
## Loading ramdisk from FIT Image at 10000000 ...
Trying 'ramdisk@0' ramdisk subimage
Description: ramdisk
Type: RAMDisk Image
Data Start: 0x10dc5884
Data Size: 172414926 Bytes = 164.4 MiB
OS: Linux
Load Address: unavailable
Entry Point: unavailable
Hash algo: sha1
Hash value: 01dd9fbcfe084bc4d82a45d8ae1d06800dcc6ae0
Trying 'fdt@0' fdt subimage
Description: Flattened Device Tree blob
Type: Flat Device Tree
Data Start: 0x10dbcdd0
Data Size: 35327 Bytes = 34.5 KiB
Hash algo: sha1
Hash value: 349030d0b6f649df3138f8f4ec1b4d139bf8591c
Booting using the fdt blob at 0x10dbcdd0
Loading Kernel Image ... OK
Loading Ramdisk to fffffffffdb92000, end 07fff7ce ... "Synchronous Abort" handler, esr 0x96000044
ELR: 7ff57ed0
LR: 7ff239ec
x0 : fffffffffdb92000 x1 : 0000000010dc5884
x2 : 000000000246dfff x3 : 0000000000000009
x4 : 0000000000000000 x5 : 0000000000000006
x6 : 0000000000000001 x7 : 000000000000000f
x8 : 000000007dec83d0 x9 : 0000000000000008
x10: 000000007dec7c71 x11: 0000000000000021
x12: 0000000000000008 x13: 00000000ffffffff
x14: fffffffffdb92000 x15: 0000000000000002
x16: 0000000007fff7ce x17: ffffffffffffffff
x18: 000000007dec8de8 x19: 000000007ff8abc0
x20: 0000000010dc5884 x21: 0000000008000000
x22: 000000000a46d7ce x23: 000000007ff8abc8
x24: 000000007ff8abf0 x25: 000000007ff7e810
x26: 00000000100000d8 x27: 000000007ff0bae4
x28: 0000000000080000 x29: 000000007dec8520
Resetting CPU ...
resetting ...
PMUFW: PmSystemShutdown: (1)
PMUFW: PmInitSuspendCb: of NODE_RPU (203, 4294967295, 0, 0)
  看起来好像是犹豫ramdisk的尺寸过大导致的,如何修改这个尺寸呢?或者有什么其他的方法将QT加入到linux系统中?
0 项奖励
3 条回复3
2,671 次查看
注册日期: ‎08-01-2007
回复: 使用petalinux 增加QT库,导致image.ub变大,引导失败。
可以参考 UG1144 - Configuring SD Card ext filesystem Boot 章节,把rootfs放在SD的第二个分区。
0 项奖励
Visitor first_blood
407 次查看
注册日期: ‎11-29-2018
我想知道你硬件版本是rev1.0还是1.1,还有就是你是否移植hello world打印成功过?
0 项奖励
385 次查看
注册日期: ‎11-06-2018
确实有这个问题,我把selfhosted加上以后,image.ub也变大了,200多MB,引导失败,也是跟你差不多同一个位置,我以前也是放到第二个引导区成功过,你可以试试分区
0 项奖励
