取消
显示结果
搜索替代
您的意思是:
Visitor kaikaokao
3,680 次查看
注册日期: ‎08-17-2016
如何在Vivado中修改综合、布局布线和生成bit流的设置?
转到解答
用ISE时有综合、布局布线和生成bit流时都有很多选项,但是Vivado中可选的很少。那个高手知道在Vivado中这些选项怎么修改,麻烦指点一二。
例如 write_bistream options:
Option Name             | Current Setting         |
| STARTCBC                | (Not Enabled)*          |
| EXTMASTERCCLK_EN        | DISABLE*                |
| SECURITY                | NONE*                   |
| XADCENHANCEDLINEARITY   | OFF*                    |
| CONFIGFALLBACK          | DISABLE*                |
| TCKPIN                  | PULLUP*                 |
| DISABLE_JTAG            | NO*                     |
| PROGPIN                 | PULLUP*                 |
| OVERTEMPPOWERDOWN       | DISABLE*                |
| USERID                  | 0XFFFFFFFF*             |
| PERSIST                 | NO*                     |
| DCIUPDATEMODE           | ASREQUIRED*             |
| GWE_CYCLE               | 6*                      |
| STARTUPCLK              | CCLK*                   |
| PARTIAL                 | (Not Enabled)*          |
| ACTIVERECONFIG          | NO*                     |
| TDOPIN                  | PULLUP*                 |
| TIMER_USR               | 0X00000000*             |
| KEYFILE                 | (Not Enabled)*          |
| HKEY                    | (Not Enabled)*          |
| KEY0                    | (Not Enabled)*          |
| M0PIN                   | PULLUP*                 |
| TMSPIN                  | PULLUP*                 |
| NEXT_CONFIG_REBOOT      | ENABLE*                 |
| READBACK                | (Not Enabled)*          |
| CONFIGRATE              | 3*                      |
| SPI_BUSWIDTH            | NONE*                   |
| JTAG_XADC               | ENABLE*                 |
| CCLKPIN                 | PULLUP*                 |
| DEBUGBITSTREAM          | NO*                     |
| NEXT_CONFIG_ADDR        | 0X00000000*             |
| DONE_CYCLE              | 4*                      |
| CRC                     | ENABLE*                 |
| INITSIGNALSERROR        | ENABLE*                 |
| COMPRESS                | FALSE*                  |
| XADCPOWERDOWN           | DISABLE*                |
| M1PIN                   | PULLUP*                 |
| REVISIONSELECT          | 00*                     |
| M2PIN                   | PULLUP*                 |
| SELECTMAPABORT          | ENABLE*                 |
| SPI_32BIT_ADDR          | NO*                     |
| BPI_1ST_READ_CYCLE      | 1*                      |
| ENCRYPTKEYSELECT        | BBRAM*                  |
| ICAP_SELECT             | AUTO*                   |
| DONEPIPE                | YES*                    |
| TANDEM_WRITEBITSTREAM   | COMBINED*               |
| MATCH_CYCLE             | AUTO*                   |
| XADCPARTIALRECONFIG     | DISABLE*                |
| BPI_PAGE_SIZE           | 1*                      |
| TDIPIN                  | PULLUP*                 |
| UNUSEDPIN               | PULLDOWN*               |
| PERFRAMECRC             | NO*                     |
| REVISIONSELECT_TRISTATE | DISABLE*                |
| GTS_CYCLE               | 5*                      |
| INITPIN                 | PULLUP*                 |
| ENCRYPT                 | NO*                     |
| BPI_SYNC_MODE           | DISABLE*                |
| USR_ACCESS              | (Not Enabled)*          |
| TIMER_CFG               | 0X00000000*             |
| DONEPIN                 | PULLUP*                 |
| SPI_FALL_EDGE           | NO*                     |
| LCK_CYCLE               | NOWAIT*                 |
这些选项怎么修改?如果选项太多了可用将UNUSEDPIN修改为FLOAT为例。
冰天雪地裸体跪求!!!!
0 项奖励
1 个已接受解答
已接受的解答
5,582 次查看
注册日期: ‎07-28-2016
回复: 如何在Vivado中修改综合、布局布线和生成bit流的设置?
转到解答
Vivado也提供了相应的设置,具体步骤如下:
1. 打开综合后的设计(Open Synthesized Design)
2. 在菜单下选择Tools --> Edit Device Properties
就可以看到相应的内容。
1 条回复1
5,583 次查看
注册日期: ‎07-28-2016
转到解答
就可以看到相应的内容。
