ntutangyun
virtex 7 vc 707 board: how to write drivers to access the USER SMA GPIO
Hi, all
I'm quite new here.
I wish to communicate with the VC707 board through an antenna connected to the USER SMA GPIO port.
So i wish to write a driver to read and write on the USER GPIO ports. but i didn't find the memory address assoicated to the GPIO port.
Does anyone know where to find relavent resources.
Thanks in advance.
bruce_karaffa
Where to begin?
The Virtex 7 is a digital logic chip.  It expects a logic type signal on all of its pins.  An antenna will only convert an RF signal into a very low level electrical signal.  To interface with an FPGA, you would need to amplify the output of  the antenna, filter the signal, downconvert and demodulate it, then convert the demodulated signal to a string of ones and zeroes.
The SMA port goes to a pin on the device.  It is just a pin, no address, just a physical location.  You could put a microblaze into your design and access the pin through that.  In general, using an FPGA means designing digital hardware, not writing a sequential program.
ntutangyun
oh god. Thank you so much for your reply. Would you mind recommending a better approach if i would wirelessly communicate with the board.
Thank You. :)
