取消
显示结果
搜索替代
您的意思是:
742 次查看
注册日期: ‎10-16-2018
请教:用k7 FPGA 6个gtx收发器实现6路sdi接口时 placement时报错
请教: vivado 中报错如下 是什么原因导致?
[Place 30-140] Unroutable Placement! A GTXE_COMMON / GTXE_CHANNEL clock component pair is not placed in a routable site pair. The GTXE_COMMON component can use the dedicated path between the GTXE_COMMON and the GTXE_CHANNEL if both are placed in the same clock region. If this sub optimal condition is acceptable for this design, you may use the CLOCK_DEDICATED_ROUTE constraint in the .xdc file to demote this message to a WARNING. However, the use of this override is highly discouraged. These examples can be used directly in the .xdc file to override this clock rule.
< set_property CLOCK_DEDICATED_ROUTE FALSE [get_nets U_sdi_6ch_top/U_sdi_ch1/gtxe2_common_0/qpllclk] >
U_sdi_6ch_top/U_sdi_ch1/gtxe2_common_0/gtxe2_common_i (GTXE2_COMMON.QPLLOUTCLK) is provisionally placed by clockplacer on GTXE2_COMMON_X0Y0
U_sdi_6ch_top/U_sdi_ch1/SDI1/SDI/GTX_i/gtxe2_i (GTXE2_CHANNEL.QPLLCLK) is locked to GTXE2_CHANNEL_X0Y4
U_sdi_6ch_top/U_sdi_ch1/SDI0/SDI/GTX_i/gtxe2_i (GTXE2_CHANNEL.QPLLCLK) is locked to GTXE2_CHANNEL_X0Y5
The above error could possibly be related to other connected instances. Following is a list of
all the related clock rules and their respective instances.
Clock Rule: rule_gt_bufg
Status: PASS
Rule Description: A GT driving a BUFG must be placed on the same half side (top/bottom) of the device
U_sdi_6ch_top/U_sdi_ch0/SDI0/SDI/GTX_i/gtxe2_i (GTXE2_CHANNEL.RXOUTCLK) is locked to GTXE2_CHANNEL_X0Y7
U_sdi_6ch_top/U_sdi_ch0/SDI0/SDI/BUFGRX (BUFG.I) is provisionally placed by clockplacer on BUFGCTRL_X0Y31
Clock Rule: rule_gtxcommon_gtxchannel
Status: PASS
Rule Description: A GTXCommon driving a GTXChannel must both be in the same clock region
U_sdi_6ch_top/U_sdi_ch0/gtxe2_common_0/gtxe2_common_i (GTXE2_COMMON.QPLLOUTCLK) is provisionally placed by clockplacer on GTXE2_COMMON_X0Y1
U_sdi_6ch_top/U_sdi_ch0/SDI0/SDI/GTX_i/gtxe2_i (GTXE2_CHANNEL.QPLLCLK) is locked to GTXE2_CHANNEL_X0Y7
U_sdi_6ch_top/U_sdi_ch0/SDI1/SDI/GTX_i/gtxe2_i (GTXE2_CHANNEL.QPLLCLK) is locked to GTXE2_CHANNEL_X0Y6
Clock Rule: rule_bufds_gtxchannel_intelligent_pin
Status: PASS
Rule Description: A BUFDS driving a GTXChannel must both be placed in the same or adjacent clock region
(top/bottom)
U_sdi_6ch_top/MGTCLKIN1 (IBUFDS_GTE2.O) is locked to IBUFDS_GTE2_X0Y4
U_sdi_6ch_top/U_sdi_ch1/SDI1/SDI/GTX_i/gtxe2_i (GTXE2_CHANNEL.GTREFCLK1) is locked to GTXE2_CHANNEL_X0Y4
U_sdi_6ch_top/U_sdi_ch1/SDI0/SDI/GTX_i/gtxe2_i (GTXE2_CHANNEL.GTREFCLK1) is locked to GTXE2_CHANNEL_X0Y5
U_sdi_6ch_top/U_sdi_ch0/SDI0/SDI/GTX_i/gtxe2_i (GTXE2_CHANNEL.GTREFCLK1) is locked to GTXE2_CHANNEL_X0Y7
U_sdi_6ch_top/U_sdi_ch0/SDI1/SDI/GTX_i/gtxe2_i (GTXE2_CHANNEL.GTREFCLK1) is locked to GTXE2_CHANNEL_X0Y6
Clock Rule: rule_bufds_gtxcommon_intelligent_pin
Status: PASS
Rule Description: A BUFDS driving a GTXCommon must both be placed in the same or adjacent clock region
(top/bottom)
U_sdi_6ch_top/MGTCLKIN0 (IBUFDS_GTE2.O) is locked to IBUFDS_GTE2_X0Y2
U_sdi_6ch_top/U_sdi_ch1/gtxe2_common_0/gtxe2_common_i (GTXE2_COMMON.GTREFCLK0) is provisionally placed by clockplacer on GTXE2_COMMON_X0Y0
U_sdi_6ch_top/U_sdi_ch0/gtxe2_common_0/gtxe2_common_i (GTXE2_COMMON.GTREFCLK0) is provisionally placed by clockplacer on GTXE2_COMMON_X0Y1
Status: PASS
U_sdi_6ch_top/U_sdi_ch0/SDI1/SDI/GTX_i/gtxe2_i (GTXE2_CHANNEL.RXOUTCLK) is locked to GTXE2_CHANNEL_X0Y6
U_sdi_6ch_top/U_sdi_ch0/SDI1/SDI/BUFGRX (BUFG.I) is provisionally placed by clockplacer on BUFGCTRL_X0Y29
Status: PASS
U_sdi_6ch_top/U_sdi_ch1/SDI0/SDI/GTX_i/gtxe2_i (GTXE2_CHANNEL.RXOUTCLK) is locked to GTXE2_CHANNEL_X0Y5
U_sdi_6ch_top/U_sdi_ch1/SDI0/SDI/BUFGRX (BUFG.I) is provisionally placed by clockplacer on BUFGCTRL_X0Y25
Status: PASS
U_sdi_6ch_top/U_sdi_ch1/SDI1/SDI/GTX_i/gtxe2_i (GTXE2_CHANNEL.RXOUTCLK) is locked to GTXE2_CHANNEL_X0Y4
and U_sdi_6ch_top/U_sdi_ch1/SDI1/SDI/BUFGRX (BUFG.I) is provisionally placed by clockplacer on BUFGCTRL_X0Y23
0 项奖励
6 条回复6
704 次查看
注册日期: ‎10-16-2018
回复: 请教:用k7 FPGA 6个gtx收发器实现6路sdi接口时 placement时报错
求解^^
0 项奖励
672 次查看
注册日期: ‎08-26-2010
Hi @yongkangbi,
是否做了参考钟,GTXE2_COMMON_xxxx以及Channel的位置约束?看起来是因为约束不正确导致不能走专用路径导致的错误。
Simon
0 项奖励
Community Manager
Community Manager
663 次查看
注册日期: ‎08-31-2011
一个quad里有一个common和四个channel。
从报错来看,你ch0是channel的x0y4和x0y5, 对应的应该是common的x0y1,而不是common的x0y0.
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
0 项奖励
652 次查看
注册日期: ‎10-16-2018
您好,这个约束应该怎么写呢??谢谢!
0 项奖励
650 次查看
注册日期: ‎10-16-2018
您好,没有做位置约束,您能给个这个位置约束的参考么?谢谢
0 项奖励
632 次查看
注册日期: ‎08-26-2010
Hi @yongkangbi
可以参考example里的约束来做相应的修改,比如:
set_property LOC AA30 [get_ports  Q0_CLK1_GTREFCLK_PAD_N_IN ]
set_property LOC AA29 [get_ports  Q0_CLK1_GTREFCLK_PAD_P_IN ]
##---------- Set placement for gt0_gth_wrapper_i/GTHE2_CHANNEL ------
set_property LOC GTHE2_CHANNEL_X0Y0 [get_cells xaui_wrapper_support_i/xaui_wrapper_init_i/
inst/xaui_wrapper_i/gt0_xaui_wrapper_i/gthe2_i]
##---------- Set placement for gt1_gth_wrapper_i/GTHE2_CHANNEL ------
set_property LOC GTHE2_CHANNEL_X0Y1 [get_cells xaui_wrapper_support_i/xaui_wrapper_init_i/
inst/xaui_wrapper_i/gt1_xaui_wrapper_i/gthe2_i]
##---------- Set placement for gt2_gth_wrapper_i/GTHE2_CHANNEL ------
set_property LOC GTHE2_CHANNEL_X0Y2 [get_cells xaui_wrapper_support_i/xaui_wrapper_init_i/
inst/xaui_wrapper_i/gt2_xaui_wrapper_i/gthe2_i]
##---------- Set placement for gt3_gth_wrapper_i/GTHE2_CHANNEL ------
set_property LOC GTHE2_CHANNEL_X0Y3 [get_cells xaui_wrapper_support_i/xaui_wrapper_init_i/
inst/xaui_wrapper_i/gt3_xaui_wrapper_i/gthe2_i]
Simon
0 项奖励
