Considering Pin Delay for DDR3
I want to consider the pin delay value of XC7K325T for DDR3 in my design. The pin delay value from Vivado is the min / max time value. Which value should I use, min and max?
Re: Considering Pin Delay for DDR3
The flight time in the package needs to be accounted for when you are doing the trace matching for DDR.
I think we say you should pick the mid point between the min and max number I think. I can double check for you
