Decoupling VREFCA or VREFDQ to VDD in DDR3 design
In ZedBoard's DDR3 design, the VREFCA and VREDDQ not only decoupled to GND, but also to VDD/VDDQ. But in other boards, such as MicroZed or ZC702, the pin only decoupled to GND.
Note: The schematic shows VREFCA decoupled to VDD, and VREFDQ decoupled to GND.
Are there any advantages to decouple it both to GND and VDD?
Tags (2)
Re: Decoupling VREFCA or VREFDQ to VDD in DDR3 design
Two hypothetical advantages:
1.  (If we assume that the power supply impedance is zero) using two caps will halve the high frequency impedance seen by the Vref pin (when compared to a single capacitor), assuming the two capacitors are located appropriately.
2.  Vref is supposed to track the supply voltage divided by 2.  Using two capacitors of equal capacitance makes a voltage divider that will correctly track the short term variations in the supply voltage (as opposed to a single cap to ground that will act as a low pass filter and NOT track the short term variations in the supply voltage).
BTW, If there was no noise and a perfect PCB layout, neither point would matter.  But there is always noise, and PCB layouts are always a compromise between several conflicting requirements.
