Interfacing Artix 7 with CMOS image sensors
Accepted Solution Solved
Accepted Solution
    I've a requirement to interface a CMOS Image sensor(MT9P006) with Artix7 FPGA. I've to perform image processing including autofocus and interfacing with USB 3.0 peripheral controller IC. Is it possible with artix7??? If yes, then what are the tools (like vivado ISE etc) required and what will be the expected cost for those tools... Is there any free software alternatives for them???
Thank you...
Re: Interfacing Artix 7 with CMOS image sensors
As far as interfacing goes, yes, the Artix-7 is fine for interfacing with the OnSemi image sensors.  I'm working on an Artix-7 interface to the OnSemi Python 1300 series right now.
For Artix-7, you will need the Vivado toolset.   Since the MT9P006 is a parallel CMOS output, you won't have to do anything fancy with LVDS bit alignment or bitslip word alignment, so it should be fairly straightforward, although you will need to read the datasheet very carefully, some of the OnSemi sensors have odd pixel readout sequences.
Since this is your first time using Artix for video applications, I recommend you purchase an evaluation board such as the Digilent Nexys Video board available here:
     http://store.digilentinc.com/nexys-video-artix-7-fpga-trainer-board-for-multimedia-applications/
it works with the free Xilinx webpack version of Vivado, which supports the XC7A100TFGG484 used on the Nexys board:
      https://www.xilinx.com/products/design-tools/vivado/vivado-webpack.html
I don't know what you will need for your image processing functions, so you will have to do further research to determine if the XC7A100 has enough horsepower for your needs.
All Replies
