Visitor raj@1994
Reading stored data from BRAM
Hi All,
I Stored coe file in BRAM IP. I used attached block diagram to read the value from BRAM ip. Below are the c code that i have used. But i didn't get output in SDK terminal. Can anyone help me out ?
#include "Xparameters.h"
#include "xbram.h"
#include <stdio.h>#include "xil_io.h"
#define XPAR_AXI_BRAM_CTRL_0_S_AXI_BASEADDR 0x40000000
int main()
int w1;
int w2;
w1=Xil_In32(XPAR_AXI_BRAM_CTRL_0_S_AXI_BASEADDR);
w2=Xil_In32(XPAR_AXI_BRAM_CTRL_0_S_AXI_BASEADDR+4);
xil_printf("%x",w1);
xil_printf("%x",w2);
return 0;
Mentor hgleamon1
Mentor
Re: Reading stored data from BRAM
If you debug the code and watch the variables, what values do you get when you step through the code?
How are you connecting the SDK terminal? What is defined in your subsystem to be the STDIN/OUT?
"That which we must learn to do, we learn by doing." - Aristotle
Visitor raj@1994
I connected SDK terminal using gpio ip and com port. I'm new to this domain. Can you plz guide me how to get the stored data to SDK terminal . Is there is any document for C code. Thanks in advance!!
Mentor hgleamon1
Mentor
You didn't answer my question about what was defined to be the stdio in your subsystem (in the BSP)?
I think the SDK terminal uses the JTAG connection but if you have an external connection that should probably be some UART.
Visitor raj@1994
Thanks for your reply.
I don't have much knowledge about C code in SDK. I want to read the stored data (.coe file) from BRAM IP and to display the same through VGA. I'm able to build the block diagram but unable to write c code to communicate PS and PL. Could you plz help me ?
Have a good day!!
Mentor hgleamon1
Mentor
After a quick inspection, there isn't anything wrong with the C code you have previously posted.
However, you haven't explained what debug you have attempted. Can you debug the application on your target and see that the variables acquire the values you expect when you expect them to?
It's still not clear to me how you are connecting the console to the system in order to see the values printed out to the terminal. Can you explain this a little bit more?
Visitor raj@1994
Im able to read the BRAM content through SDK terminal now.
Mentor hgleamon1
Mentor
That's good.
For reference, you should explain what you have done to resolve your issue and then close this thread by marking your resolution message as solved.
