SFP Implementation-KC705(Aurora)
            I am trying to implement the optical communication through SFP from Kintex 7 (KC705) to another FPGA K7 board.
while generating the bit stream in Tx board(KC705), I encountered the error"Check Timing". I am using Aurora 8b10b.
Re: SFP Implementation-KC705(Aurora)
If you are only testing Aurora IP example, you can ignore those warnings.
Hi abinaya1991@
you have encountered this timing errors because you didnt set proper set_input_delay and set_output_delay constraints for your design.
Vinay
