Visitor hbaumann
XADC predifined Package Pins ?
I included an XADC-Core into my design and want to assign the external ports (vn_in, vp_in) to a specific Package Pin.
My Problem is that i cant choose those Package Pins in the "I/O Ports"-view for the vn_in/vp_in -ports.
It seems like they are in some sort predefined because Vivado only offers me only one Package Pin to chose from.
For vn_in i can only choose Package Pin "L10" or "<Unplace>".
P.S. there are plenty of free Package Pins left.
What I am doing wrong, what I am missing, which circumstances can lead to this ?
Heiko
Scholar drjohnsmith
Re: XADC predifined Package Pins ?
yep
the analog pins are special
and are only on certain pins ,
Hi @hbaumann
Vp_0 and VN_0 are dedicated differential analog input pair and User do not have control to choose the package pins. Package pins are fixed for this input.
Reply if you have any queries, Give Kudos and Accepts as Solution
Visitor hbaumann
Hi @pthakare
Thanks for the quick answer !
Does this also apply for the "vaux"-ports ?
I have the same problem with them. For example I can only chose between "B20" or "<Unplace>" for port "vauxn0".
This applies for all the XADC-ports you can see in my screenshot. The selected Package Pins there are the only ones I can choose.
Heiko
Scholar drjohnsmith
yep
Visitor hbaumann
Ok thanks for the quick help @pthakare and @drjohnsmith
