Newbie brianwtec
Zync 7000 Family with Main Memory ECC
I'm researching SOC solutions for a project I'm working on.
The project requires ECC DRAM for the main processor.
I have found techical notes and questions in the forums about using ECC on Zync 7000, but I haven't been able to confirm a few basic needs of the project:
1. Does the part support ECC on main memory?
2. Does it run full speed, or is there a speed limitation?
3. What is the typical width of main memory, is it 32 or 64 bits? In other words does it do 4 bit ECC or 8 bit ECC?
4. Is ECC a hard macro, a soft macro or a mix of the two?
I'd love some feedback from someone who's designed ECC onto a system with the Zync just to make sure the project is viable with Zync.
Thanks much.
Re: Zync 7000 Family with Main Memory ECC
starting page 292 ug585
https://www.xilinx.com/support/documentation/user_guides/ug585-Zynq-7000-TRM.pdf
Table 10.1, page 295,
"Total Data Width (bits) 16, 32 ECC can only use a 32-bit configuration: 16 data bits, 10 check bits"
l.e.o.
https://www.xilinx.com/support/answers/58684.html
DDR only,  no ECC on OCM, nor caches.
l.e.o.
Newbie brianwtec
Thanks for responding.
I'm sorry, I wasn't clear. I wasn't asking about OCM. I was asking about the SOC's DDR main memory. Does that support full speed ECC DRAM? If so, what width is it?
l.e.o.
Newbie brianwtec
Thanks l.e.o. That answers my question.
