Observer eldercosta
Zynq PL: inferring LVDS as a bus
Hello.
I have a design with 34 LVDS inputs and I would like to treat them as a bus, i.e. connecting them internally through a generate clause (VHDL) and have the synthesizer to resolve it to LVDS pairs with the pin constraints configuration file.
I mean, say the single-ended inputs in my design are something like
MY_LVDS_BUS : out std_logic_vector (33 downto 0);
and I want to connect it to an MY_LVDS_BUS input bus on the Zynq bd. Then I would like to have it mapped to MY_LVDS_BUS[i]_P and MY_LVDS_BUS[i]_N in the device.
Is it possible?
Re: Zynq PL: inferring LVDS as a bus
@eldercosta
I'm not sure that I understand the question.   Maybe the following is what you want?
Use the VHDL signal vector in your design:
signal MY_LVDS_BUS : std_logic_vector (33 downto 0);
Add the following outputs to the top-level VHDL module in your design:
MY_LVDS_BUS_P : out std_logic_vector (33 downto 0);
MY_LVDS_BUS_N : out std_logic_vector (33 downto 0);
Use the differential signal output buffer, OBUFDS, by instantiating it into your VHDL design as follows (see UG953 for details):
GEN1: for i in 0 to 33 generate
   MY_LVDS: OBUFDS
      generic map(
         IOSTANDARD => "LVDS",
         SLEW => "SLOW")
      port map(
         O => MY_LVDS_BUS_P(i),
         OB => MY_LVDS_BUS_N(i),
         I => MY_LVDS_BUS(i)
end generate GEN1;
Write constraints that look something like the following:
set_property IOSTANDARD LVDS [get_ports {MY_LVDS_BUS_P[*]}]
set_property IOSTANDARD LVDS [get_ports {MY_LVDS_BUS_N[*]}]
set_property PACKAGE_PIN U12 [get_ports {MY_LVDS_BUS_P[33]}]
set_property PACKAGE_PIN AB13 [get_ports {MY_LVDS_BUS_P[32]}]
# Here, specify P-side pin for all other LVDS pin-pairs (31 down to 0).
# You do not need to specify N-side pins
Cheers,
Mark
@eldercosta
   MY_LVDS: OBUFDS
      generic map(
         SLEW => "SLOW")
      port map(
         I => MY_LVDS_BUS(i)
end generate GEN1;
Cheers,
Mark
Observer eldercosta
Hello, Mark.
It's been a while, with another tool and (non Xilinx) FPGA  but I am quite sure I could declare an LVDS in or out without the _[P|N] suffix and the pin constraint was all that the tool needed to define a differential pair (not saying Vivado's or Xilinx's way is worse, just different).
Anyway your answer provides a way nearly as simple to achieve what I need.
Thank you very much.
Elder.
