Participant ahmed_alfadhel
how to read from IOmodule ?
Hi ,
I want to read data from IOmodule, then send this data to a PmodDA3 module using Microblaze.
What is the right procedure to read data from IOmodule ?
Kindly, find the attached picture.
Thanks in advance.
Scholar drjohnsmith
Re: how to read from IOmodule ?
There should be a set of IO routines generated when you generated the iomodule, long time since I've done this sorry, but they used to be in the folder.
then you just use the read / write procedures provided,
the bit map for the IO module, as to what address and what bit to do something with is int he doc for the IO module
Its basically a C question
https://www.xilinx.com/support/documentation/ip_documentation/iomodule/v3_1/pg111-iomodule.pdf
