2017.4 - Create boot image
Hi all,
I just upgraded Vivado and SDK from 2016.4 to 2017.4 and now I have problems understanding the programming process. In the latest version there is a separate FSBL required but the first stage bootloader is already saved in the *.bin or *.mcs file. I just pointed to the same location as I did for bootimage generation:
Furthermore I get (with two boards) the error that the flash content could not be deleted:
I do not have these problems with the old version.
Kind regards
Sebastian
Re: 2017.4 - Create boot image
Look at AR70148
回复: 2017.4 - Create boot image
Hi, is your problem solved ?
I also have some questions when use 2017.4. I do the same as the figure, and the Flash programmed successful, but power on again ,the QSPI not initiate. I don't know how to do next
Have you changed the boot mode to QSPI after programming the boot.bin?
