Visitor fknudsen
AXI Quad SPI delaying data transfer
I am using the AXI Quad SPI IP to communicate with a slave device. In order to do this, the slave requires that the slave select signal is low for a certain amount of time before any data can be received or sent by the slave. Is there any way to implement a time delay between the slave select signal going low and data being transmitted over the MOSI-wire?
Thank you,
Frederik
Scholar jg_bds
Re: AXI Quad SPI delaying data transfer
The AXI Quad SPI IP supports a "manual slave select mode".  This mode should allow you to assert slave select an arbitrary amount of time prior to presenting data on MOSI, or toggling SCLK.
-Joe G.
