ZzSun
After switching to QSPI mode, init_ B signal is always at low level, and when JTAG is connected, the following warning will be given
After switching to QSPI mode, init_ B signal is always at low level, and when JTAG is connected, the following warning will be given:
CRITICAL WARNING: [Labtools 27-3421] xczu27dr_0 PL Power Status OFF, cannot connect PL TAP. Check POR_B signal.
abommera
Hi @ZzSun,
>> Make sure all your power rails are above threshold levels before and during the configuration.
>> Are you configuring FPGA from QSPI flash? Seems your bit file might be corrupted. Can you try without bit file in your boot image?
Thanks & Regards
Anil B
