Boot-up failure; stuck at PMUFW
Hi:
I am bringing up a ZCU19EG board. Currently, the configuration is set such that the boot-mode is QSPI. Kernel is taken from SD card. Everything was working fine.
However, about a couple of days ago, the board rebooted automatically and stuck at PMUFW. On power cycling the board or rebooting it, makes it do the same. (Start FSBL >> Get stuck at PMUFW).
Log:
Xilinx Zynq MP First Stage Boot Loader
Release 2018.1 Aug 20 2018 - 14:51:43
PMU Firmware 2018.1 Aug 20 2018 14:52:54
PMU_ROM Version: xpbr-v8.1.0-0
NOTICE: ATF running on XCZU19EG/silicon v4/RTL5.1 at 0xfffea000
NOTICE: BL31: Secure code at 0x0
NOTICE: BL31: Non secure code at 0x8000000
NOTICE: BL31: v1.4(release):xilinx-v2017.4-1351-gdf4a7e97
NOTICE: BL31: Built : 21:50:22, Aug 20 2018
PMUFW: v1.0
Moreover, I tried to program the PL of Zynq with Vivado and the JTAG won't connect to the PL.
Log from Vivado Hardware manager:
CRITICAL WARNING: [Labtools 27-3421] xczu19_4 PL Power Status OFF, cannot connect PL TAP.  Check POR_B signal.
ERROR: [Labtools 27-3165] End of startup status: LOW
ERROR: [Common 17-39] 'program_hw_devices' failed due to earlier errors.
I tried flashing the QSPI with JTAG (while the board still in QSPI mode). I got the following log:
****** Xilinx Program Flash
****** Program Flash v2018.1 (64-bit)
**** SW Build 2188600 on Wed Apr 4 18:40:38 MDT 2018
** Copyright 1986-2018 Xilinx, Inc. All Rights Reserved.
Connected to hw_server @ TCP:127.0.0.1:3121
Available targets and devices:
Target 0 : jsn1
Target 1 : jsn2
Target 2 : jsn-DLC10-000016c4525f01
Device 0: jsn-DLC10-000016c4525f01-1396d093-0
Device 1: jsn-DLC10-000016c4525f01-1396d093-1
Device 2: jsn-DLC10-000016c4525f01-1396d093-2
Device 3: jsn-DLC10-000016c4525f01-1396d093-3
Device 4: jsn-DLC10-000016c4525f01-14758093-0
Retrieving Flash info...
Initialization done, programming the memory
ERROR: [Xicom 50-60] Connect operation failed. Please make sure that the device is active.
Problem in Connecting to Target
Flash programming initialization failed.
ERROR: Flash Operation Failed
Please help me understand how is JTAG disabled in the board? Is there a setting/bit set which closes the PL TAP/JTAG connection of Zynq?
Re: Boot-up failure; stuck at PMUFW
Hi @shantan1
In Zynq Ultrascale+ MPSOC reset is generated by the two reset controllers; one for each of the power domains (LPD and FPD). The primary device-level reset inputs are from the PS_POR_B and PS_SRST_B device pin, which must be asserted and deasserted based on specific conditions. The operation of the reset unit requires the PS_REF_CLK to be active.
Check  UG1085 (v1.8) (Page 1124~1125) for more information
Check PS_REF_CLK status on your board.
Bhushan
Bhushan
Mentor watari
Mentor
Hi @shantan1
I'm not sure. But it seems power lane issue.
Would you make sure power lane on FPGA ?
Almost all POR_B issue is caused by power lane problem.
Best regards,
Hi @shantan1
Bhushan
Bhushan
Solved the problem. Zynq was held in reset by another circuitry. Since the architecture is confidential to my company, I cannot reveal the low-level details, I apologize. However, it was the problem with external resets certainly.
