chepner
Bootgen - BOOT.bin Image generation Issue
I'm trying to use bootgen to generate a BOOT.bin for my ZCU102 with Zynq UltraScale+ MPSoC without good results.
The .bif that i'm using is:
//arch = zynqmp; split = true; format = BIN
image : {
[bootloader,destination_cpu=a53-0] zynqmp_fsbl.elf
[pmufw_image] zynqmp_pmufw.elf
[destination_cpu=a53-0, exception_level=el-3, trustzone] bl31.elf
[destination_cpu=a53-0, exception_level=el-2] u-boot.elf
[load=0x02000000] uimage.ub
But, I encountered this issue in generation.
Trace :
[INFO] : Building image - the_ROM_image
[TRACE] : Setting Core as 2
[DEBUG] : ELF Header size wrong - 20496, actual size - 64
FILE: elftools.cpp
LINE: 175
[ERROR] : ELF Parsing Error !!!
Wrong Header Size
Can help me debugging this issue ?
Chepner
denist
I noticed "split = true". Is that on purpose? Usually you want a monolithic BOOT.bin.
Also, which elf file is having issues? fsbl? pmufw?
We had problem in the past with come compilation settings that would create "strange" linking for the elf.
For example FSBL has to be a contiguous file (no multiple partitions) if I recall correctly.
chepner
Hello @denist,
I don't know which elf file is having issue. I'm searching for this information because no information in bootgen utility trace.
I removed split = true but i'm facing the same issue.
denist
On the .bif add a file at the time and see if you can identify which file is creating issues to bootgen.
