Observer spiwoks
Booting ZynqMP brings up only ONE CPU!
Hi all,
I am trying to boot a ZynqMP using JTAG according to the Zynq UltraScale+ MPSoC
Software Developer Guide. It works and boots Linux but only brings up ONE CPU.
I am using a TE0803 from Trenz and I have contacted them, but since booting the same
files from an SD card, they told me that only Xilinx can help me with this.
Any idea? On what could be wrong? Is it some register setting?
Cheers,
                            Ralf.
Observer spiwoks
Re: Booting ZynqMP brings up only ONE CPU!
Hi Kranthi,
Thank you so much for your reply.
The kernel command-line parameter "maxcpus=4" did the trick. Now it brings up all four CPUs.
Cheers,
                         Ralf.
@spiwoks,
Can you try adding "maxcpus=4" in kernel boot arguments? which version of petalinux/Kernel you are using?
Can you check how many cores are defined in "cpus" device node in your device tree?
Kranthi
Best Regards
Kranthi
Observer spiwoks
Hi Kranthi,
Cheers,
                         Ralf.
