Booting issue with Minized
I am following the "Booting MiniZed Using QSPI and eMMC" guide to learn how to create my own BSP for the Minized:
http://zedboard.org/sites/default/files/design/Booting_MiniZed_Using_QSPI_and_eMMC_2017_2_01.zip
I program flash with BOOT.bin and to copy image.ub  into eMMC, as indicated into Experiment 3: U-BOOT should be able to recognize eMMC and jump to it to start linux image.
But it fails....
The error message is:
"Card did not respond to voltage select!
 MMC Device 0 not found
 no mmc device at slot 0"
Has someone already replicated this issue or could someone test the flow?
Re: Booting issue with Minized
Hi @colombini_luca
Try this below  fourm links, looks it will help you to solve the issue.
https://forums.xilinx.com/xlnx/board/crawl_message?board.id=ELINUX&message.id=20442
https://forums.xilinx.com/t5/Embedded-Linux/U-Boot-fails-to-initialize-SD-card-on-ZCU102/td-p/876818
Thanks & regards
Aravind
