Bootrom and bad blocks in NAND
How, if at all, bootrom handles bad blocks in NAND flash during boot process? Does it read bad block table, or checks information in OOB memory of first page in block?
Re: Bootrom and bad blocks in NAND
Hi  Saleksin,
The BootROM manages bad blocks in the following ways:
• It looks for a bad block table (BBT) in the last four blocks of the NAND flash device.
• It supports a primary and secondary BBT with versioning allowing safe software updates.
• If a BBT is not present, the BootROM scans the flash reading the out-of-band (OOB) information
to determine the locations of bad blocks.
• The BootROM only performs read operations – it does not write to the flash.
While reading from NAND, the BootROM skips blocks that are marked as bad in the BBT, or in the
OOB information if a BBT does not exist.
For more information please read 6.3.5 NAND BOOT in ug585.
Best Regards,
Srikanth
Hi  Saleksin,
Best Regards,
Srikanth
Many thanks!
