Observer nrubeli
Bug Report - Xilskey library
When using the secure key driver to load the hash of a RSA PPK into the PS eFuse (following XAPP1175) the PS Data Initialization is going to fail. This due to an error in the following function:
PsStatus = XilSKey_Efuse_ConvertStringToHexBE(
					XSK_EFUSEPS_RSA_KEY_HASH_VALUE,
					&(PsInstancePtr->RsaKeyHashValue[0]), 64);
if(PsStatus != XST_SUCCESS) {
      return PsStatus;
In this function it fails at this particular part:
u32 XilSKey_Efuse_ConvertStringToHexBE(const char * Str, u8 * Buf, u32 Len)
if(Len != (strlen(Str)*4U)) {
		Status=(u32)XSK_EFUSEPS_ERROR_PARAMETER_NULL;
		goto END;
Len is a hardcoded 64 and Str is the ppk hash (string containing 64 chars)...
So it actually executes:
if(64 != (64*4U)) {
		goto END;
Len is therefore tha length of the hash in bits and should be 256 and not 64!
Best regards
Re: Bug Report - Xilskey library
Which version of the tool is this? Which example does have this call?
PsStatus = XilSKey_Efuse_ConvertStringToHexBE(XSK_EFUSEPS_RSA_KEY_HASH_VALUE,&(PsInstancePtr->RsaKeyHashValue[0]), 64);
Observer nrubeli
I downloaded it using the link provided in the xapp1175 docu.
The zip folder includes an readme which states date last modified: 13AUG2019 Version (1.2)
BUT: The included xilskey_efuse_example.c file is still version 1.00a (first release)
The referenced function:
&(PsInstancePtr->RsaKeyHashValue[0]), 64); is defined in xilskey_utils.c which in turn is version 6.7
I hope that helps
The example has been fixed for the 2020.1 release.
Thanks for reporting this.
