Can dual cores boot up at a same time?
Hi everyone,
Is there a way to boot up both cores baremetal at a same time? Or zynq only allows to start up in an amp way that core0 boots up first and core1 boots up next by core0 ?
Best Regads,
rj
Re: Can dual cores boot up at a same time?
In zynq-7000 FSBL only run on core0. Then FSBL can kick of the second core.
Thank you @denist,
Then, Can I load a single ELF to both cores by FSBL and let dual cores access the same piece of code? Is it doable?
rj
You need to keep the read/write data sections independent but the read only section of code should be possible to have it in common.
