Configure L2 Cache as SRAM for Booting u-boot
Hi all
I want to use l2 cache controller to keep u-boot for Booting on ZED Board
Is iot possible , if so please provide me procedure,
if not please provide me the valid reason why it is not?
Thanks in advance
Satish G
G Satish Kumar
Re: Configure L2 Cache as SRAM for Booting u-boot
Do you want to use cache as a normal memory? L2 cache is only 512KB, It’s not enough to store the u-boot image.
If you would like to load a sequence of code/data into the L2 cache controller.
See the following example:
http://www.wiki.xilinx.com/Zynq-7000+AP+SoC+Boot+-+Locking+and+Executing+out+of+L2+Cache+Tech+Tip
