oceanlogic
Creating boot image with Vivado 2019.1 : create button inactive
I followed this tutorial with Vivado 2019.1. Everything is fine, looks pretty much the same, except at the very end when I need to create the boot image. If you look at 7:36, once I add the FSBL.elf, the "Create Image" button below becomes active. Not for me.
And it doesn't change when adding the .bit and the other .elf .
Any ideas ?
oceanlogic
Never mind, I needed to fully specify the .bif output path. Putting simply output.bif probably ended up in some installation directory with no write permisison. Anyway, with a well specified path, the button is now highlighted.
oceanlogic
