Visitor omerirmak
Disabling serial console?
I want to disable serial terminal and only use SSH for terminal access. But when I disable the autooconfig for "Serial Settings" and pass "console=tty0" or empty string as bootargs I cannot get Zynq to boot. The error I get is below;
INFO: Launching XSDB for file download and boot.
INFO: This may take a few minutes, depending on the size of your image.
INFO: Configuring the FPGA...
INFO: Downloading bitstream to the target.
INFO: Downloading ELF file to the target.
Memory write error at 0x8008000. Cannot access DDR: the controller is held in reset
    invoked from within
"::tcf::eval -progress {
        apply {{info} {
        switch -- [lindex $info 0] {
            "info" {
            puts -nonewline "\r[lindex $info 1]"
            "warning" {
            puts "\n[lindex $info 1]"
            "data" {
            puts -nonewline "\r[lindex $info 1] of [lindex $info 2] complete"
            "done" {
        flush stdout
        ::xsdb::abort_check
        }}} {::tcf::cache_enter tcfchan#0 {tcf_cache_eval {download_cache_client ::tcfclient#0::arg}}}"
    (procedure "::tcf::cache_eval_with_progress" line 2)
    invoked from within
"::tcf::cache_eval_with_progress $params(chan) [list download_cache_client $argvar] {
        apply {{info} {
            "info" ..."
    (procedure "dow" line 77)
    invoked from within
"dow -data "./linux_project/images/linux/system.dtb" 0x08008000"
    (file "/tmp/tmp.kycnOvA6n7" line 26)
INFO: The XSDB log is as follows
attempting to launch hw_server
****** Xilinx hw_server v2018.2
  **** Build date : Jun 14 2018-20:18:37
    ** Copyright 1986-2018 Xilinx, Inc. All Rights Reserved.
INFO: hw_server application started
INFO: Use Ctrl-C to exit hw_server application
INFO: To connect to this hw_server instance use url: TCP:127.0.0.1:3121
100%    3MB   1.8MB/s  00:02
mctrlval=30800100
Downloading Program -- ./linux_project/images/linux/zynq_fsbl.elf
    section, .text: 0x00000000 - 0x00005c5b
    section, .handoff: 0x00005c5c - 0x00005ca7
    section, .init: 0x00005ca8 - 0x00005cbf
    section, .fini: 0x00005cc0 - 0x00005cd7
    section, .rodata: 0x00005cd8 - 0x00005f4b
    section, .data: 0x00005f50 - 0x00008b97
    section, .eh_frame: 0x00008b98 - 0x00008b9b
    section, .mmu_tbl: 0x0000c000 - 0x0000ffff
    section, .init_array: 0x00010000 - 0x00010003
    section, .fini_array: 0x00010004 - 0x00010007
    section, .rsa_ac: 0x00010008 - 0x0001103f
    section, .bss: 0x00011040 - 0x0001143f
    section, .heap: 0x00011440 - 0x0001343f
    section, .stack: 0xffff0000 - 0xffffd3ff
100%    0MB   0.7MB/s  00:00
Setting PC to Program Start Address 0x00000000
Successfully downloaded ./linux_project/images/linux/zynq_fsbl.elf
Downloading Program -- ./linux_project/images/linux/u-boot.elf
    section, .text: 0x00400000 - 0x0044038f
    section, .rodata: 0x00440390 - 0x0044e080
    section, .hash: 0x0044e084 - 0x0044e09b
    section, .dtb.init.rodata: 0x0044e0a0 - 0x004515ff
    section, .data: 0x00451600 - 0x00453caf
    section, .got.plt: 0x00453cb0 - 0x00453cbb
    section, .u_boot_list: 0x00453cbc - 0x00454ba3
    section, .efi_runtime: 0x00454ba8 - 0x00454ca7
    section, .efi_runtime_rel: 0x00454ca8 - 0x00454d37
    section, .rel.dyn: 0x00454d38 - 0x0045e5c7
    section, .bss_start: 0x00454d38 - 0x00454d37
    section, .bss: 0x00454d38 - 0x0047571b
    section, .bss_end: 0x0047571c - 0x0047571b
100%    0MB   0.6MB/s  00:00
Setting PC to Program Start Address 0x00400000
Successfully downloaded ./linux_project/images/linux/u-boot.elf
  0%    0MB   0.0MB/s  ??:?? ETA
Failed to download ./linux_project/images/linux/system.dtb
I am trying to boot via JTAG.
Thank you in advance.
Re: Disabling serial console?
Hi @omerirmak,
Instead of above changes, you can try in petalinux to disable Uarts in device tree.
1. Add below changes to <petalinux project>/project-spec/meta-user/recipes-bsp/device-tree/files/system-user.dtsi
    &Uart1 {
                status = "disabled";
   &Uart0 {
Kranthi
Best Regards
Kranthi
Visitor omerirmak
Hi @gudishak,
Thank you for the response.
Quick question, would this disable the uart modules alltogether? I want to be able to use them for other purposes.
Omer
@omerirmak,
They will be disabled by Kernel. I hope you can use for own purpose
Kranthi
Best Regards
Kranthi
