Visitor carol@chiang
Failed to download fsbl.elf when booting from JTAG (with zu29dr)
I was using prebuilt files from zcu1275 and tried to boot my new board with zu29dr (not zcu1275 though). When I used JTAG to boot up the device, it got error during downloading fsbl.
I followed steps from Xilinx wiki https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841655/Prepare+Boot+Medium#PrepareBootMedium-JTAGBoot
and used 2018.3 environment. The message is shown as the following:
xsct% connect
tcfchan#1
xsct% targets
1* PS TAP
2 PMU
3 PL
4 PSU
5 RPU (Reset)
6 Cortex-R5 #0 (RPU Reset)
7 Cortex-R5 #1 (RPU Reset)
8 APU (L2 Cache Reset)
9 Cortex-A53 #0 (APU Reset)
10 Cortex-A53 #1 (APU Reset)
11 Cortex-A53 #2 (APU Reset)
12 Cortex-A53 #3 (APU Reset)
xsct% targets 1
xsct% dow fsbl.elf
Failed to download C:/Users/lidar-demo/Documents/xilinx-zcu1275-2018.3/pre-built/linux/images/fsbl.elf
xsct% Code 16 Time 1569873371263 Format {Invalid context}
dow zynqmp_fsbl.elf
Failed to download C:/Users/lidar-demo/Documents/xilinx-zcu1275-2018.3/pre-built/linux/images/zynqmp_fsbl.elf
The fsbl.elf is actually not in the directory but zynqmp_fsbl.elf is. Any suggest to fix it?
Thank you
Re: Failed to download fsbl.elf when booting from JTAG (with zu29dr)
Problem is that you are selecting the incorrect target. Can you try:
# Download Hello World to A53 #0
targets -set -filter {name =~ "Cortex-A53 #0"}
dow fsbl.elf
con
after 500
stop
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/84444479/TCL+script+to+auto-generate+a+jtag+boot+script+based+on+HDF+file+for+Zynq+Ultrascale
Mentor watari
Mentor
Hi carol@chiang
Would you change directory ?
ex.
Old
New
C:/work/fsbl.elf
Best regards,
dow fsbl.elf
con
after 500
stop
I also found the same procedure on "https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_1/ug1209-embedded-design-tutorial.pdf" p.92.
Along with https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841655/Prepare+Boot+Medium JTAG part, I reached to "starting kernel" but failed. Something wrong with dtb, image (kernel), and rootfs.
But anyway. Still thank you both. It really helped.
