Observer martin6314
Failing TSGEN timer access after FSBL authentication boot
Our design (ultrascale+, standalone, A53, SDK 2017.4) uses the timer TSGEN (master timestamp generator) for A53 load measurement.
On not authenticated boot, timer access is possible as expected:
  • TSGEN.CNTCR (0xfe900000) can be written and
  • TSGEN.CNTCVL (0xfe900008) can be read.
After authenticated boot, writing TSGEN.CNTCR causes the CPU to hang.
The register csu_status is 0 in the not authenticated case and 1 (authenticated) in the authenticated case, as expected. The image was built using
the_ROM_image:
 [pskfile] key\psk.txt
 [sskfile] key\ssk.txt
 [fsbl_config] bh_auth_enable
 [auth_params] ppk_select=0; spk_id=0x00000000
 [destination_cpu=a53-0,authentication=rsa,bootloader]FSBL.elf
 [destination_device=pl,authentication=rsa]Fpga.bit
 [destination_cpu=pmu,  authentication=rsa]PMU.elf
 [destination_cpu=a53-0,authentication=rsa]Core1.elf
 [destination_cpu=a53-1,authentication=rsa]Core2.elf
bootgen -image Test.bif -arch zynqmp -efuseppkbits key\pkhash.txt -w on -p XCZU2CG -o Test.bin
The UG1085 technical reference manual states that <<Software with sufficient privilege can read this counter.>>
So we assume a problem with the exception level of the Core.
This seems to indicate that we need to go the ARM trusted firmware route (ATF),
which seems to be a longer run and I wanted to avoid this as for now.
Can anyone explain me. If we want to use authentication:
1) Do we have to go the path of ATF and [trustzone,exception_level=el-3]
2) why access to TSGEN fails after FSBL authentication boot?
Thank you
Martin
Re: Failing TSGEN timer access after FSBL authentication boot
I believe the TSGEN is a timestap in the debug coresight which is disable by default when booting securely.
Take a look at AR#68391
Some of those instruction should re-enable access to coresight components.
I don't know which one.
Denis
Denis
Observer martin6314
Hi Denis
Thank you very much for your suggestion. As you mentioned, not all instructions are required to enable TSGEN. The following instruction is sufficient:
    Xil_Out32(0xFF5E0240,0x0);
Thanks again very much for this helpful information!
Martin
