Flashing QSPI configuration memory device in Vivado Lab Edition 2019.1
I am trying to use Vivado Lab Edition 2019.1 to flash my configuration memory(mt25ql series) with mcs file after generating the mcs through the Vivado. After adding the configuration memory and trying to flash it with the generated mcs file, it throws an error after stopping at 1%. The FPGA used is XCZU7EV.
回复: Flashing QSPI configuration memory device in Vivado Lab Edition 2019.1
I wanted to know whether it's possible with the Vivado Lab edition and we figured what did we miss. It's that for the initial programming of mcs into the flash, I should have programmed the FPGA with the .bit file and write the .mcs file into the flash through the FPGA. Then from the next time its booting up, it will boot from the flash. I missed the initial FPGA configuration.
Thank you for your support.
What is the error?
It says " There is one error message while Program Configuration Memory Device" and Flash Programming Unsuccessful. Please find the Tcl console messages included with this.
Can you make sure that mode pins are set in JTAG mode? Also what if you try to use and program the flash? Does that work.
For zynq MPSOC devices you need to set the mode to JTAG while programming flash and later you can set the mode QSPI while booting up from flash.
--harshit
It's set in JTAG mode at the start, i.e. when trying to flash the PROM. If it's after successfully flashing the PROM, I am supposed to switch it off and change the mode to QSPI to turn it back on in QSPI boot mode. What do you mean by "Also what if you try to use and program the flash? ".Is it like programming the flash through some other direct means instead of the indirect flashing through the FPGA?
-Thank you
Sorry for the typo. I missed the SDK from my reply.
> Have you tried SDK to program the flash?
https://www.xilinx.com/html_docs/xilinx2018_1/SDK_Doc/SDK_references/sdk_u_program_flash.html
Let us know what error you get?
Harshit
