Observer dagan.martinez
Getting a baremetal application on the RPU to start a baremetal application on the APU
I have an FSBL running on a53_0(though it could run on the r5), a baremetal application on the a53_0, and a baremetal application on the r5_0.
What I want is for the FSBL to start the application on the r5_0, which then starts the application on the a53_0 at its leisure. The application on the a53_0 should then terminate itself.
What currently happens is the FSBL loads both applications, which run concurrently.
Can somebody point me in the right direction?
Re: Getting a baremetal application on the RPU to start a baremetal application on the APU
Your RPU app would need to take responsibility to load APU app and tick it.
Or you can let FSBL load both, then put a wait loop in your ar53 app which can be terminated by R5 app though a flag from shared memory or inter-processor interrupt (IPI)
FSBL loads the partitions one after other and once loading of all partitions is complete, handing off to CPUs of corresponding partitions is done by FSBL.
If you don’t want FSBL to load that partition you need to modify the FSBL code or the simple way is to change the partition_owner to u-boot in the BIF file for your a53_0 app.
Check ug1137 for the details of partition_owner parameters.
Thank you, Ritakur, that was helpful. Do you how I could start the APU application after the RPU application starts?
