mvorbach
How to program QSPI with ZYNQ configuration and bare metal program
Is it possible to program the QSPI on the ZC706 board with the ZYNQ FPGA fabric configuration and a bare metal program?
Such that it automatically starts after power on?
I did not find any useful documentation.
BTW: I am still using 2015.4
glena
You can look at UG1165.   The Linux flow shows much of what you need to do.
After your Vivado design creation and export:
1) create FSBL
2) create application
3) generate a programming image (bif file)
4) program boot flash
5) set configuration pins to you boot flash
