Visitor spectranetix
Intermittent eMMC boot problems
XCZU4EG and XCZU19EG both intermittently fail to boot from Micron MTFC16GAAECN-4M. When boot fails, the FSBL is not started and register PMU_GLOBAL.CSU_BR_ERROR reports 0x80003B00
All of the changes recommended in AR71019 have been implemented.
I think my PCB layout and hardware are OK because when the fsbl runs, the PL is loaded and u-boot and
Linux load and run with out problems. Also, when the system is booted from JTAG, there haven't been problems formatting
the eMMC and writing files to it.
We are using Vivado 2018.2.1 and Petalunux 2018.2
Re: Intermittent eMMC boot problems
Hi @spectranetix,
From the BootROM Error Code register, 0x3B(check TRM ug1085) represents "Reading failed from the selected boot device." So BootROM is not able  read the information (like FSBL) to OCM.
Kranthi
Best Regards
Kranthi
Hi Gudishak,
Thanks for your response.
We know that when the system doesn't boot it's because the CSU can't read in the FSBL.
Our question is why does  it boot most of the time but fails occasionally? Is there anything we can do
to make it more robust?
Dan Moyles
Spetranetix Inc
@spectranetix,
Have you tried decreasing the speed of SDIO and boot?
Is everything working fine at standalone sdk examples for SD/eMMC?
Kranthi
Best Regards
Kranthi
In the past I saw similar behaviors if the power up sequence is not respected and the IO are coming up NOT tristated.
I suggest to run the standalone example (based on Xilffs) to "stress test" the hardware and see if you can reproduce a failure.
From what you are describing, you should power cycle between tests and always boot in JTAG boot mode.
Maybe a XSCT tcl script is best.
We have implemented the changes in AR69368 and the FSBL, u-boot and Linux are all running the eMMC at 50 MHz. However,it appears that the boot failure occurs when the CSU is trying to download the FSBL, so dropping the clock frequency does not fix the problem.
WRT the power-up sequence, the MIO and eMMC are using the same +1.8V supply. The eMMC +3.3V supply is brought up simultaneously with the +1.8V. The PS_POR_B signal is controlled by the +1.8V and is released about 100ms after the +1.8V is good.
Our fix is to replace the Micron MTFC16GAKAECN-4M with MTFC8GAKAJCN-4M. The 8G part boots without problems.
It appears that there is a compatibility issue with Zynq Ultrascale+ and Micron MTFC16G
I am surprised about the claim but MTFC16G is NOT in the list from AR#65463.
I am glad you found a valid alternative.
