Is there a way for PL to load only encrypted bitstream?
FPGA:ZYNQ-7000
I set up eFuse through vivado:
I want pl to load only bitstream encrypted with my key in any case.
And now, I can still load unencrypted bitstream through uboot's "fpga load" command.But I don't want unencrypted bitstream to load.
So, is there a way for pl to load only encrypted bitstream?
Or,is there a way I can make sure the bitstream going into the PL config module will always be sent to the AES/HMAC engine?
In zynq-7000, I am pretty sure you have to use RSA to force the partititon (in this case bitstream) to be encrypted.
Also, be sure to check this knwon issue: https://www.xilinx.com/support/answers/71437.html
In MPSoC the ENC_ONLY eFUSE actually enforce to have every single parititon encrypted.
Thank you for your reply.
Can this approach prevent unencrypted bitstream loading?
@xiyue5137
Correct me if I'm wrong, but my thought is that a bitstream is a sequence of bits, how does the PL figure out if it's encrypted or not?
Advisor
Advisor
@archangel-lightworks wrote:
@xiyue5137
The bitstream is more than just the raw configuration bits; there's a fair bit of metadata too.
With that said, the goal is essentially to force the FPGA to decrypt every bitstream with the pre-programmed key. If the bitstream was not actually encrypted, or was encrypted with a different key, then the result will be a mess which will immediately fail the FPGA's own validity check - so it won't get loaded. The only way to get a functional design will be to give it a bitstream encrypted with the correct key, as intended.
