JTAG keeps disconnecting
Using the below mentioned JTAG cable HS2 from trenz electronics and trying to connect to Zynq7035 is being disconnected every now and then .
JTAG cable:HS2 Trenz
Clock Freq:125KHz (can this be changed on the above mentioned cable?)
I've seen that this cable has worked at 10MHz previously on the same board, all of sudden I can only recognize the board at 125KHz.
This is the error message I see:
ERROR: [Labtoolstcl 44-513]  HW Target shutdown. Closing target: localhost:3121/xilinx_tcf/Digilent/210249A7306F
intermittent problems like this are normally broken / mechanical problem with the cables.
or blown driver chips / power supplies on the board.
or software .
You say this cable has worked at 10 Mhz, has it worked on this machine at that speed ?
At a firs toff, I'd get the scope out, and trace the JTAG signals around the board, to see if they all look nice voltage levels and shape of signal.
As its a digilent programmer , you might want to ask on the digilent forum also
or software .
Yes, You were right, it was a power supply isssue.
