Loading a new bitstream file from an external peripheral device
Is is possible to load or stream a bitstream file from an external peripheral device (over IIC or SPI) and update the Kintex-7 FPGA at runtime, and then boot the FPGA with the new version of the bitstream? Or is this only possible using JTAG with iMPACT, Vivado, or other Xilinx tools? As I understand, iMPACT only works over UART, or am I mistaken?
回复: Loading a new bitstream file from an external peripheral device
Hi @mrh973,
K7 have five configuration interfaces, please see cha2, ug470.
If other configuration interface was used, you need to instantiate a ICAP primitive, then deliver data to the ICAP from SPI or I2C.
Simon
Hi @mrh973,
Simon
