Mask poll failed at ADDRESS: 0xFD4023E4 MASK: 0x00000010
Hello all,
I am working with a custom board that uses the UltraSOM+ MPSoC XCZU9EG-1FFVC900E from Trenz. Previously I worked using the ZCU102 board, so what I did is to migrate one easy project that blinks a led to the new board, using the board files from Trenz. The bitstream was successfully created. I launched the SDK and I programmed the FPGA without problems. The problem was when "Launching on hardware", that a message appeared with the following error:
"Error while launching program:
Timeout Reached. Mask poll failed at ADDRESS: 0xFD4023E4 MASK: 0x00000010"
Do you know what is happening? Has anybody encountered a similar error?
Thanks and best regards,
baldrism
Re: Mask poll failed at ADDRESS: 0xFD4023E4 MASK: 0x00000010
You'll find the register 0xFD4023E4 defined as L0_PLL_STATUS_READ_1 in UG1087.
In your code you can find this register in psu_init.c.   The issue you are seeing is the serdes is not initialzing.    How did you port your ZCU102 design?
Hello @glena ,
Thank you very much for your answer. This problem appeared using my custom board and not the ZCU102 board. My custom board has a SOM from Trenz company, and I am using the board files provided by them. I created a dummy project, where it is instantiated the Zynq Processor and a GPIO IP block. After generating the bitstream, I launch the SDK and I did a dummy software that blinks a led using the AXI GPIO. However I get this error when trying to launch any software in the Zynq UltraScale. I worked before using the ZCU102 board  and I never get this error before.
Do you know how can I find the focus of this problem?
baldrism
The issue is with the SERDES polling loop.   Make sure you have your SERDES correctly configured.
Sorry @glena ,
I am pretty new about this topic. How can I know if the SERDES is correctly configured?
baldrism
I would suggest a serach in the forums and Xilinx.com on SERDES and see where that leads you.
SERDES configuration is beyond the scope of this forum.   I've indentified your boot isse as a SERDES issue.
Observer sahebi.amin
Hi there,
if the problem still remains unsolved, please comment four lines for mask_poll 0XFD4023E4 0x00000010 in psu_init.tcl in the wrapper_hw_platform directory, then run the configuration, it should work.
