11-18-2019 01:11 PM
I am creating authenticated image which is loaded from uboot via "secure" call ... essentially following #4 on here:
Since I have no PSK, I am using SSK and SPKsignature in my bif file. After I got the auth image, I ran bootgen_utility and the Heade Table AC is missing BH signature. It does have SPK and Paritition signature.
The partition Data AC (for single image paritition), has the BH Signature.
According to UG 1085, BH AC should have BH Signature.
What I am missing ... ????
thanks ...
11-22-2019 11:53 AM - edited 11-22-2019 11:55 AM
Which version of the tools? Can you please post your .bif file and the bootgen command you used?
11-23-2019 05:30 PM
I am on 2018.3
This generates hashes :
bootgen -arch zynqmp -image hash.bif -generate_hashes -w on -log error
hash:
[auth_params] ppk_select=0; spk_select=spk-efuse; spk_id=0
[ppkfile] PPK0_pubkey.txt
[sskfile] SPK0_privkey.txt
[spksignature] SPK0_pubkey.pem.sha384.sig
[destination_device=ps,
authentication=rsa,
] temp.bin
I sign with openssl and then insert sig into certificate:
AC:
authentication=rsa,
presign=temp.bin.0.sha384.sig
] temp.bin
using
bootgen -arch zynqmp -image ac.bif -o temp.bin.auth -nonbooting -w on -log error
This gives me an image which "secure" is happy with i.e. no errors. I am finding it strange that BH sig is missing from Header AC. I know that "secure" is working as I tried changing SPK/ppk-select and it would fail for me...
11-25-2019 02:10 PM
In the HSM flow described in UG1283 you have to add the BH signature explictly to the partititon using the attribute [bhsignature]bootheader.sha384.sig. It's stage 7 in Figure 16 page 74.
Now for single independent partititon, teh BH signature might nor be used by XilSecure when loading since there's no BH to authenticate in that step.
11-26-2019 11:34 AM
It is not just for the bif files I attached. I looked at my boot.bin which follows the HSM model, and the Header Table AC section does not have bhsignature as well. I think it this is due to the fact that the header table partition signature is essentially bhsignature.
11-27-2019 09:59 AM
you missing the bhsignature entry in your bif?
Stage7a:
[fsbl_config] bh_auth_enable
[ppkfile] primary.pub
[spkfile] secondary.pub
[spksignature]secondary.pub.sha384.sig
[bootimage,authentication=rsa,presign=fsbl.elf.0.sha384.sig]fsbl_e.bin
