MultiBoot register address on RfSoc
Hi all,
I'm looking for address of CSU mutliboot register address on Zynqmp Ultrascale+ RfSoCs.
Before I was using 0xFFCA0010 on Zynqmp Ultrascale+ MpSoCs, and it worked fine.
The address I've taken from site: https://www.xilinx.com/html_docs/registers/ug1087/ug1087-zynq-ultrascale-registers.html
I was getting the value hidden under that address using XFsbl_In32 in FSBL code
Now on Zynq Ultrascale+ RfSoC ZU27DR I'm doing the same, but I'm always getting value 0 this time.
Is there maybe such site also for RfSoCs? I couldn't find it through xilinx site nor with the help of Google.
Hope to hear from you soon,
Best regards,
Filip Wozniak
Re: MultiBoot register address on RfSoc
The processing system is the same in RFSoC.    The multiboot address register is 0xFFCA0010 as you stated.   What different behavior are you seeing?   Do you have multiple images in your boot flash?
In the end I've found that multiboot was cleared in some other part of the code.
It was code introduced by someone from my company.
So everything works fine now :)
Thanks for reply
BR,
Filip Wozniak
