Observer erliangyun666
PS Read PL Configuration through PCAP in ultrazed SOM
Dear
I desinged a simple ip and would like to read the configuration bit from PL to PS through PCAP. I reffered the xfpga_readback_example_1 in baremetal not linux, but it does not work, whether it is because this "PMU-FW is not running, certain applications may not be supported" , are there any demos for this, thank you very much!
Re: PS Read PL Configuration through PCAP in ultrazed SOM
How did get these numbers for XCZU3EG?
#define FRAMES 14964
#define WORDS_PER_FRAME 93
#define PAD_FRAMES 1
The example should be working and I am pretty sure it doesn't require the PMUFW.
How are you running it? Booting from a flash (FSBL + example) or directly from JTAG (Debug As flow)?
Thank you very much!
I checked the FSBL + example and directly from JTAG, but they all failed. My board is XCZU3EG SOM instead of the zcu102 board. I changed the frames, and other paramters as follows:
except for this change, i didn't modify others in the xfpga_readback_example_1 demo. I confused almost two weeks without progress. Can you give me some suggestions. Thanks again.
Best wishes!
I refer this, is it correct?
Thanks a lot.
Best wishes!
Hi @erliangyun666,
You are correct on the FRAMES and WORD_PER_FRAMES.
May I ask why you changed the PAD_FRAMES from 25 to 1?
My understanding is that should remain at 25 but I can double check that for you.
You mention that it's not working. Can you clarify what is not working?
  • Are you successfully able to readback but do not see the expected data readback?
  • Or you can't even perform the readback?
Wendy
Xilinx Technical Support
Xilinx Zynq MP First Stage Boot Loader
Release 2019.2 Dec 9 2019 - 16:07:29
FPGA Configuration data Read back example
FPGA Configuration Read back Failed
FPGA Configuration Read back example Failed
It reports like this
Thank you, even though this time, i changed that to 25, it still reported failed
In jtag and debug mode, when i comment out the following code in static u32 XFpga_GetPLConfigData(const XFpga *InstancePtr) in xilfpag_pcap.c
/*Status = XFpga_GetFirmwareState();
if (Status == XFPGA_FIRMWARE_STATE_UNKNOWN) {
Xfpga_Printf(XFPGA_DEBUG, "Error while reading configuration "
"data from FPGA\n\r");
Status = XFPGA_ERROR_PLSTATE_UNKNOWN;
goto END;
if (Status == XFPGA_FIRMWARE_STATE_SECURE) {
Xfpga_Printf(XFPGA_DEBUG, "Operation not permitted\n\r");
Status = XFPGA_FAILURE;
goto END;
it can read some byte and output like this
PMU-FW is not running, certain applications may not be supported.
Bitstream contents are
0000 0000 0000 0000 0000 0000 0000 0000
however, when i change it to SD mode, even though comment out the code, the output is like this
and after some while, it output
I don't know how to solve it, can you give me some help
Thank you very much
Best wishes
