douglas.yamamoto
Programming Flash via JTAG
Attempting to program a custom board that uses an UltraScale+ chip, XCZU2CG-2SFVC784I.  Using the Program Flash tool in Xilinx SDK 2017.4, I have attempted to program a Micron MT25QU01G series memory device that is connected via a QSPI Parallel connection.
I have created a very bare-bones firmware that sends a discrete signal periodically to an IC on the board.  The bitstream was generated and the .hdf file was exported to Vivado, where I used the template Application Projects to create a FSBL for a MPSoC UltraScale device.  A project was created using the 'Hello World' example project.  A .bin file was created using the Create Boot Image tool in SDK.  The .bif specified the FSBL.elf file, followed by the firmware's .bit file, and ended with the Hello World's .elf file.  The .bin file was selected in the Program Flash tool to begin programming the Flash device.
If I use the default Auto-Connect option for the Device selection, on the Program Flash GUI, I receive an error.
****** Xilinx Program Flash
****** Program Flash v2017.4 (64-bit)
  **** SW Build 2086221 on Fri Dec 15 20:55:39 MST 2017
    ** Copyright 1986-2017 Xilinx, Inc. All Rights Reserved.
Connecting to hw_server @ TCP:127.0.0.1:3121
Connected to hw_server @ TCP:127.0.0.1:3121
Available targets and devices:
Target 0 : jsn1
Target 1 : jsn2
Target 2 : jsn-DLC9LP-0000116f9c8701
ERROR: Unable to detect JTAG cable
If I manually select the device to the local connection to the board, I receive a different error.
Target 0 : jsn1
Target 1 : jsn2
	Device 0: jsn-DLC9LP-0000116f9c8701-14711093-0
Retrieving Flash info...
Initialization done, programming the memory
Problem in Connecting to Target
Flash programming initialization failed.
ERROR: Flash Operation Failed
I'm not sure what the next steps from here are, I have looked through quite a few AR's and have not had any promising leads.  Any help is appreciated, thank you.
denist
Here the reccomandation on that Flash Programming error:
https://www.xilinx.com/support/answers/73223.html
denist
It appeard an issue wiht connecting to the cable rather than Flash programming itself.
Maybe you can try to connect XSDB or Vivado HW Manager to see if that's working.
The "DebugTools" forum might be able to help you better on this issue.
douglas.yamamoto
Any suggestions on what sort of commands I should be using with XSCT?  When I run the command "targets" this is what I see.
targets
  1  PS TAP
     2  PMU
     3  PL
  4  PSU
     5  RPU (Reset)
        6  Cortex-R5 #0 (RPU Reset)
        7  Cortex-R5 #1 (RPU Reset)
     8  APU (L2 Cache Reset)
        9  Cortex-A53 #0 (APU Reset)
       10  Cortex-A53 #1 (APU Reset)
xsct%
douglas.yamamoto
As a sanity check, I was able to use the same cable to program a ZCU102 evaluation board.  There was a difference in the firmware and software used, but the template for the FSBL was still used.  Beginning to check the schematic of my board against the ZCU102 schematic to see if any details arise.  Are there any suggestions in the mean time?
denist
The target list looks ok. Can you please report on these two XSCT commands:
jtag targets
jtag servers
douglas.yamamoto
Here is the XCST Console, starting from a new session with Xilinx SDK 2017.4
xsct% jtag targets
xsct% Invalid target. Use "connect" command to connect to hw_server/TCF agent
connect
tcfchan#1
xsct% jtag targets
  3  Platform Cable USB 0000116f9c8701
     4  xczu2 (idcode 14711093 irlen 12 fpga)
     5  arm_dap (idcode 5ba00477 irlen 4)
xsct% jtag servers
  digilent-ftdi cables 0
  xilinx-ftdi cables 0
  digilent-djtg cables 0
  xilinx-pcusb cables 1
xsct%
denist
What concerms me is that you have multiple Targets (0, 1 and 2) listed when doing the flash programming.
I don't know how to explain it. Do you have other cables attached to the host machine? Did you try to reboot it?
This is how it should look like:
****** Program Flash v2019.1 (64-bit)
**** SW Build 2552052 on Fri May 24 14:49:42 MDT 2019
** Copyright 1986-2019 Xilinx, Inc. All Rights Reserved.
WARNING: Failed to connect to hw_server at TCP:127.0.0.1:3121
Attempting to launch hw_server at TCP:127.0.0.1:3121
Target 0 : jsn-JTAG-SMT2NC-210308A1CBE5
Device 0: jsn-JTAG-SMT2NC-210308A1CBE5-14738093-0
===== mrd->addr=0xFF5E0204, data=0x00000000 =====
BOOT_MODE REG = 0x0000
Downloading FSBL...
Running FSBL...
Finished running FSBL.
denist
Is the host a  Windows 10 machine?
I found an internal reference to a problem with some Windows 10 machines.
Can you upgrade SDK to 2018.x or 2019.1?
... or ... there's should eb no issue with Vivado HW Manager Flash Programming.
douglas.yamamoto
Could you specific what you're referencing when you asked about rebooting?  The board, SDK, the computer?  I haven't tried to disconnect other devices, but when I look at the Device Manager on my computer I only see the one programming cable.
The machine is running Windows 10, I will try and move to a different version of SDK and see what comes of it.
denist
