Programming ZCU1287 from SD card.
I am currently working on a ZCU1287 FPGA board. I was programming the FPGA through JTAG all these time. But I am planning to make it offline by programming through SD card. Can someone help me with this.
Thanks and Regards
Sravan
savula
Hi pulipatisravankumar@gmail.com ,
To boot from SD card on ZCU1287, you need to create Bootable image (.Bin) and put it in SD card. This .Bin image is combination of second stage boot loader and Bit file and user application and other files (PMU FM, ATF, Uboot). Please check ug1209 for more details. https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug1209-embedded-design-tutorial.pdf
Best Regards,
Srikanth
savula
Best Regards,
Srikanth
