Anusua
QSPI Flash operation failed
Hi everyone,
I am using Zynq Ultrascale+ FPGA module (xczu4ev) and I try to program the QSPI Flash using SDK 2019.1.
I get the following error:
****** Xilinx Program Flash
****** Program Flash v2019.1 (64-bit)
  **** SW Build 2552052 on Fri May 24 14:47:09 MDT 2019
    ** Copyright 1986-2019 Xilinx, Inc. All Rights Reserved.
Connected to hw_server @ tcp:lynx-dpa:3121
Available targets and devices:
Target 0 : jsn-DLC10-0000183b421201
        Device 0: jsn-DLC10-0000183b421201-04721093-0
Retrieving Flash info...
Initialization done, programming the memory
===== mrd->addr=0xFF5E0204, data=0x00000222 =====
BOOT_MODE REG = 0x0222
WARNING: [Xicom 50-100] The current boot mode is QSPI32.
If flash programming fails, configure device for JTAG boot mode and try again.
Downloading FSBL...
Running FSBL...
Finished running FSBL.
U-Boot 2019.01-07026-gae88108-dirty (Mar 22 2019 - 04:47:43 -0600)
Model: ZynqMP MINI QSPI
Board: Xilinx ZynqMP
DRAM:  WARNING: Initializing TCM overwrites TCM content
256 KiB
EL Level:       EL3
In:    dcc
Out:   dcc
Err:   dcc
ZynqMP> sf probe 0 0 0
SF: Detected s25fl512s_256k with page size 256 Bytes, erase size 256 KiB, total 64 MiB
ZynqMP> Sector size = 262144.
f probe 0 0 0
Performing Erase Operation...
sf erase 0 C0000
SF: Timeout!
SF: 786432 bytes @ 0x0 Erased: ERROR
ZynqMP> f erase 0 C0000
Erase Operation failed.
INFO: [Xicom 50-44] Elapsed time = 5 sec.
ERROR: Flash Operation Failed
The board is designed to support the QSPI frequency. The boot.bin used for programming contains PMU.elf, bl31.elf, fsbl.elf, u-boot.elf.
Unfortunately, I have seen many threads related to this, and each one of them has different solutions. I have programmed using Vivado 2019.1, and has the similar error. The Flash type used is qspi-x1-single, and qspi-x4-single throws errors as "
No SPI flash selected. Please run `sf probe'
ZynqMP> Error while communicating with SPI flash device - No SPI flash selected.
INFO: [Xicom 50-44] Elapsed time = 0 sec."
ERROR: Flash Operation Failed"
Any suggestions on how to resolve the issue? Thanks!
abommera
Hi @Anusua ,
Seems you are programming in QSPI boot mode. We recommend flash programming in JTAG boot mode. Hence, can you please change boot mode from QSPI to JTAG and try?
Thanks & Regards
Anil B
abommera
Hi @Anusua ,
Thanks & Regards
Anil B
