Questions about SD Booting Xen and Dom0
According to "http://www.wiki.xilinx.com/Building+Xen+Hypervisor+with+Petalinux+2018.1",
created a Petalinux project with xilinx-zcu102-zu9-es2-rev1.0-v2018.1-final.bsp,
directly using the pre-built images from the BSP,
copy files(BOOT.bin,Image,system.dtb,xen.ub)from <project-dir>/pre-built/linux/images,
then Boot the SD card on board and stop the u-boot autoboot.
At the u-boot prompt run:
mmc dev $sdbootdev && mmcinfo; load mmc $sdbootdev:$partid 1000000 system.dtb && load mmc $sdbootdev:$partid 0x80000 Image; fdt addr 1000000; mmc $sdbootdev:$partid 1030000 xen.ub; bootm 1030000 - 1000000
then it shows
switch to partitions #0, OK
mmc0 is current device
Device: sdhci@ff170000
Manufacturer ID: 3
OEM: 5344
Tran Speed: 50000000
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 14.8 GiB
Bus Width: 4-bit
Erase Group Size: 512 Bytes
reading system.dtb
41340 bytes read in 16 ms (2.5 MiB/s)
reading Image
134152704 bytes read in 8709 ms (14.7 MiB/s)
libfdt fdt_check_header(): FDT_ERR_BADMAGIC
mmc - MMC sub system
Usage:
mmc info - display info of the current MMC device
mmc read addr blk# cnt
mmc write addr blk# cnt
mmc erase blk# cnt
mmc rescan
mmc part - lists available partition on current mmc device
mmc dev [dev] [part] - show or set current mmc device [partition]
mmc list - lists available devices
mmc hwpartition [args...] - does hardware partitioning
arguments (sizes in 512-byte blocks):
[user [enh start cnt] [wrrel {on|off}]] - sets user data area attributes
[gp1|gp2|gp3|gp4 cnt [enh] [wrrel {on|off}]] - general purpose partition
[check|set|complete] - mode, complete set partitioning completed
WARNING: Partitioning is a write-once setting once it is set to complete.
Power cycling is required to initialize partitions after set to complete.
mmc bootbus dev boot_bus_width reset_boot_bus_width boot_mode
- Set the BOOT_BUS_WIDTH field of the specified device
mmc bootpart-resize <dev> <boot part size MB> <RPMB part size MB>
- Change sizes of boot and RPMB partitions of specified device
mmc partconf dev [boot_ack boot_partition partition_access]
- Show or change the bits of the PARTITION_CONFIG field of the specified device
mmc rst-function dev value
- Change the RST_n_FUNCTION field of the specified device
WARNING: This is a write-once field and 0 / 1 / 2 are the only valid values.
mmc setdsr <value> - set DSR register value
Wrong Image Format for bootm command
ERROR: can't get kernel image!
Re: Questions about SD Booting Xen and Dom0
@altair5683,
I think "fdt addr 1000000" command is failing.
Can you skip fdt and try below command to boot with xen.ub along with system.dtb if you are using initrd filesystem?
mmc dev $sdbootdev && mmcinfo; load mmc $sdbootdev:$partid 1000000 system.dtb && load mmc $sdbootdev:$partid 0x80000 Image; mmc $sdbootdev:$partid 1030000 xen.ub; bootm 1030000 - 1000000
Kranthi
Best Regards
Kranthi
@altair5683,
Kranthi
Best Regards
Kranthi
Succeed after following these commands:
fatload mmc 0 1000000 system.dtb; fatload mmc 0 0x80000 Image; fatload mmc 0 1030000 xen.ub; fatload mmc 0 2000000 xen-rootfs.cpio.gz.u-boot; bootm 1030000 2000000 1000000
