Anonymous
Not applicable
Reset does not work when JTAG connected
Hello, I have tested Hello World application when booted from SD card, it works but now I would to program ZYNQ using JTAG. In SDK I first program FPGA (Xilinx => Program FPGA) the FPGA Done light turn on then I load bit file and elf file in Run Configuration and connect STDIO to console and click Run, see attachment. The application works as I see the output on console but when I press reset on the board, it does not reset even the FPGA done light also gone.
I also check this when I un check "connect STDIO to Console" and connect SDK Terminal with UART configuration but there is no output.
Re: Reset does not work when JTAG connected
which version of Xilinx tool you are using?
Can you try using "disconnect" command from xsct and then try reset?
Kindly mark this post as accepted solution if it helps.
Best Regards
Kranthi
Anonymous
Not applicable
I tried with reset button after disconnect command but on console I get the following.
xsct% disconnect
xsct% Info: tcfchan#1 closed
connect
xsct% attempting to launch hw_server
****** Xilinx hw_server v2017.3
**** Build date : Oct 4 2017-20:12:17
** Copyright 1986-2017 Xilinx, Inc. All Rights Reserved.
INFO: hw_server application started
INFO: Use Ctrl-C to exit hw_server application
INFO: To connect to this hw_server instance use url: TCP:127.0.0.1:3121
error deleting "C:/Users/abcxyz/AppData/Local/Temp/tcfqtD2x6W7aD": permission denied
tcfchan#2
xsct%
Anonymous
Not applicable
I get e message of "permission denied" when I press the reset button. Is there any other command to run in xsct% before pressing reset button ?
