revital.l
SPI SREC Bootloader
This bootloader is working for me.... but I works very slow (takes 7 seconds)
How can I accelerate it?
I heard there is a dividor in the spi driver - how can I change it?
Thanks Alot,
Revital
revital.l
SW can change it through XQspiPs_SetClkPrescaler function
But we don't use spi ps but axi spi....
There is no appropriate function for that....
Revital
debugasm
Change type of bootloader.
Use a "Binary" bootloader instead of "SREC".
debugasm
revital.l
I am using a template project
There is no binary bootloader in the templates only SREC
Revital
smarell
Community Manager
Community Manager
Please refer to https://forums.xilinx.com/t5/Embedded-Development-Tools/very-slow-SPI-bootloader/td-p/642007
revital.l
It is solved...
legend198908
Hi, revital.l:
             How did you solve this problem ?  I also met this problem, my boot period is more than 32s.
20801700
This one is way faster:
https://github.com/henrikbrixandersen/elf-bootloader/blob/master/lib/sw_apps/elf-bootloader/src/elf-bootloader.c
write the elf file in your flash as it is (not in SREC format). From eb-config.h choose the base address of your elf file. You might want to change SPI_READ_OPERATION and SPI_FLASH_NDUMMY_CYCLES parameters depending on the flash setup you are using.
Btw, it is not mine, I just want to put it in here so that people with this problem can reach it easily.
bkzshabbaz
Do you have
#define VERBOSE
in your bootloader.c file?
I found that commenting out/removing that line will make the bootloader run faster.
