SPI memory read/write on Arty-A7 with Microblaze
Hi All,
I've got an Arty-A7 100T using a MicroBlaze. I am using one of the AXI QUAD SPI examples - https://xilinx.github.io/embeddedsw.github.io/spi/doc/html/api/xspi__stm__flash__example_8c.html
It builds and runs but fails when comparing the received data.
Using all the defaults it writes the data to the chip then retrieves it again.
The first 4 bytes are the command message and memory location and the remaining are the data. But when I insert a breakpoint to look at the read and write buffers the write buffer correctly shows:
WriteBuffer[0] = '\003'
WriteBuffer[1] = '\000'
WriteBuffer[2] = '\000'
WriteBuffer[3] = '\000'
WriteBuffer[4] = ' '
WriteBuffer[5] = '!'
However, the readbuffer shows the following:
ReadBuffer[0] = '\000'
ReadBuffer[1] = '\000'
ReadBuffer[2] = '\000'
ReadBuffer[3] = '\000'
ReadBuffer[4] = '\377'
ReadBuffer[5] = '!'
The remainder of the two arrays is correct. However, it seems that index 4 of the array is either skipped or incorrectly read. The first 4 bytes (0 to 3) are skipped as they are not real data.
Does anyone know why this may be occurring?
Thanks in advance!
